Is this a mod I should consider implementing
Phil
 Phil
(@phil-15)
I saw this mod on printables, but I'm not sure if this is needed or not. What are everyone's thoughts on it?
https://www.printables.com/model/1289015-prusa-core-one-bedlevel-correction-dust-cover
Prusa Core One
Napsal : 21/01/2026 2:20 am
RE: Is this a mod I should consider implementing
You don’t need it unless you need it. After running the bed level calibration, run auto-home. You can check the corners with a bubble level. If you are adventurous you can run OctoPrint on a device (like a laptop or Raspberry Pi) attached to the USB-C port on the back of your printer. There is plugin that does a bed mesh and displays a graph to show how level the bed is.
Napsal : 21/01/2026 2:55 am
Don't see the need for it. I had one Core One with an uneven bed. Moved it all the way down. Rotated lead screws until even. Done.
Napsal : 21/01/2026 5:29 pm
One thing I wanted to add is be careful printing and installing mods that change the mechanics of the printer. Some of them do more harm than good. Only if you identify a problem that is best fixed with a particular mod should you then print and install it.
Napsal : 21/01/2026 5:58 pm
Augendoc
(@augendoc)
I had an uneven bed as well. I moved Z to 275, disabled motors, and turned all three leadscrews to zero out the bed at 275. But when I moved the Z height back up to 0 the bed was tilted about 1 millimeter. My three Z motor leadscrews don't have the same pit. Two are about 2.000 mm and the right front is about 2.08mm. You should check your lead screw pitches. Several commenters have posted tools or techniques for checking the leadscrew pitch. I contacted Prusa about replacing at least one of my Z motors but its been two weeks and I haven't heard back yet.
This post was modified před 4 months by Augendoc
Napsal : 21/01/2026 6:09 pm
Unless you are getting consistent 1st layer problems, I wouldn't change anything.
Napsal : 21/01/2026 6:11 pm
abmantis
(@abmantis)
If you have a big difference between sides, then yeah, go ahead. But be very careful with it. Making the left side higher than the right one will mean that the nozzle will hit the bed if you set Z=0 on the right side when testing stuff manually.
Napsal : 24/01/2026 1:23 am
