Core One Nozzle wiper compatible with BIQU Glacier sheets (and everything else)
Core One Universal Nozzle Wiper
So far I only have a heat set insert version. I'll create one later with a threaded hole.
Napsal : 17/09/2025 12:44 am
1 lidem se líbí
chmax
(@chmax)
RE: Core One Nozzle wiper compatible with BIQU Glacier sheets (and everything else)
@hyiger is your nozzle wiper right-side compatible (by mirroring of course)? I using a slightly bigger one at the moment but I like the minimalistic style a lot!
Napsal : 27/09/2025 4:31 pm
Posted by: @chmax
Yes, I have also included a right side version as well as the g-code to move the purge line so the fan shroud doesn't bump into it. It's not a mirror since the dimensions on the left and right side are not symmetrical. I might add a little more material to stabilize it against the print bed bracket but so far, seems OK. I'm using the left side version.
Yeah, the other versions use way too much material in my opinion so I opted to shave off as much as possible in my design. I used FreeCad 1.0.2 to make it.
This post was modified před 2 months 4 times by hyiger
Napsal : 27/09/2025 4:54 pm
