Automatic top-vent opening and closing.
Borreltje
(@borreltje)
Now that in the new firmware the prompt for the top-vent dismisses after 60 seconds, I can open and close the vent remotely or automatically. I mounted a servo on top the lid (had no other way of mounting it out of sight) and I am going to connect that to the hackerboard so I can open and close the vent with some extra gcode when slicing for a specific material. I am using a Seed studio XIAO esp32s3 to run the servo, on a high or low pin the servo moves to a given angle. The high/low comes from the hacker board when I am finished.
This is just to show the auto opening and closing, it is still a work in progress but this bit works like a charm.  🙂
AutoTopVent
Veröffentlicht : 08/06/2025 9:36 am
5 weiteren Personen gefällt das
mrchristian
(@mrchristian)
RE: Automatic top-vent opening and closing.
Ha! This is is fantastic. I've been noodling on my own similar solution, but I'm approaching from the angle of popping the whole top sheet up a bit.
Veröffentlicht : 08/06/2025 9:58 am
Borreltje
(@borreltje)
Was thinking about that too, but my top-lid is closed with magnets so that didn't work for me. This was the next option for me.
Veröffentlicht : 08/06/2025 11:49 am
I am still tempted to try a "passive" solution: Mount a little lever to the vent slider on the inside of the enclosure, and a corresponding tab on top of the Nextruder -- such that they can engage if, and only if, the Nextruder moves all the way to the front, outside of the printable area. Then add some custom G-Code which lets the Nextruder push the slider to the left or right before printing, depending on the choice of filament.
Veröffentlicht : 08/06/2025 2:55 pm
mrchristian
(@mrchristian)
Oh that would be a clever (and cheap) hack!
Veröffentlicht : 08/06/2025 7:50 pm
mrchristian
(@mrchristian)
Posted by: @borreltje
Truthfully, I think your rack & pinion type setup is probably the sane approach.. I just kind of want to massively over engineer it for fun
Veröffentlicht : 08/06/2025 7:52 pm
Posted by: @jurgen-7
I couldn't resist and gave this a try... Described in a new thread to avoid polluting this one.
Veröffentlicht : 09/06/2025 7:35 pm
