Any alternative for rivets?
Page 2 / 3
k1mu
 k1mu
(@k1mu)
RE: Any alternative for rivets?
https://www.amazon.com/dp/B008MP06SG   - I ordered these as my upgrade kit didn't have a pile of spares. So far I haven't had to replace any so perhaps it wasn't necessary to get 100 more.  🙂
(Full disclosure: I work for Amazon.)
Posted : 06/08/2025 4:33 pm
zapta
(@zapta)
I learned to like these rivets. Aesthetic, easy to insert and remove, reusable, and wouldn't crack the plastic panels.
Posted : 07/08/2025 3:38 pm
evilphoton
(@evilphoton)
i wondered about the rivets too. but with the weight spread out over 11 rivets on each side for the handles, they seem fine. no vibration otherwise.
love the tool that zapta posted.
Posted : 28/10/2025 3:26 pm
GeneMpls
(@genempls)
Clecos
Clecos work for assembly
Posted : 05/11/2025 5:08 pm
Just Brad
(@just-brad)
Thanks, I will give McMaster a try... I picked up a few other items to reduce impact on shipping cost.
Posted : 10/12/2025 11:45 am
Dr. Skycat
(@dr-skycat)
Drill and Tap for M4-07 Torx screw
I quickly decided that the rivets made little sense. What I did was drill out all the side connector holes to tap for an M4-07 Torx screw.
This has proved very useful as I had been dealing with the upgrade to the core one + as well as the rebooting issue due to a lack of a effective ground from the x and y axis to the painted frame.
It's had to understand why Prusa went for the silly rivets when a m3 torx would have been a no brainer.  The m4 is a bit bigger as a result of the existing holes being to big for an M3.  But as you can see from the photos the m4's don't look that out of place.
You can order them here:
https://www.amazon.com/dp/B0FY2TFD7H?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
You can get the Tap and correct drill here:
https://www.amazon.com/uxcell-Spiral-Titanium-Machine-Threading/dp/B09TYT39LY/ref=sr_1_3?adgrpid=186566558379&dib=eyJ2IjoiMSJ9.82oh4PY909h9Y6ArM94oUHLrIWXfVDvejWlqFT0Ay7kDsRHxS_LF3XYMFNhLC6NS8aVxh51EsnfF7jHLlKWzsFS8EUMGf7OLzdZnOxLU41ktB-faY9ff4PY8HtFHKAz4PDdm2JW2uxpFfSdBksbWQ3XJ7JECwZ6a293uj3yL7H-rxWAcUDYaVgew0zpzfY21uUgbcwO0GBuMrjKlSSpB7X_-qwa0dFKJA2Plgxsm0tA.XrF8jVJTsO56WoMoLkQX_Zi26vdT9p1Xu8c3784RDIs&dib_tag=se&hvadid=779546370712&hvdev=c&hvexpln=0&hvlocphy=9060351&hvnetw=g&hvocijid=16207660410231928228--&hvqmt=b&hvrand=16207660410231928228&hvtargid=kwd-2408723580634&hydadcr=953_1015322473_14577&keywords=m4%2Bx%2B07%2Bdrill%2Btap&mcid=729f2564d5b8391fafa8eea5aac1c5ae&qid=1765393912&sr=8-3&th=1
Posted : 10/12/2025 7:16 pm
Sembazuru
(@sembazuru)
I haven't tried any of the many rivet removal tools on Printables, but my go-to method for removing the rivets (on my enclosure, I haven't built my C1+ yet) is to push from the inside. Press the center pin to recess it enough that outer leaves can collapse. Often by the time I've pushed the center pin enough, the rest of my finger is pushing on the leaves and the whole thing slides out of the hole enough to grab from the outside and fully remove it. (Or it pings across the room if I'm not careful enough.)
See my (limited) designs on:
Posted : 10/12/2025 10:01 pm
Those river removal tools suck. You need to squeeze an edge under the pin head. Which means that after a couple of rivets the perimeters of the removal tools begin to disintegrate
Posted : 10/12/2025 10:53 pm
zapta
(@zapta)
The textbook solution is to have threaded metal inserts (see pictures) and screws. But if the option is just a few threads in a thin sheet metal, I prefer the plastics inserts for long lasting maintainance.
Posted : 11/12/2025 4:29 am
NickAtNight
(@nickatnight)
I am still not exactly sure how the rivets are meant to work.  But it seems that we just have to remove the pin.  I just use the pliers to remove the pin. The base stays put.
Posted : 11/12/2025 5:58 am
Posted by: @nickatnight
After you remove just the pins, you can certainly pull away the panel while the outer collars of the rivets are still in place. The two prongs of the collar are no longer forced apart by the pin, so they can be compressed a bit and clear the hole in the metal frame.
 But the prongs have may undergone some plastic deformation and remain spread apart a bit. So it may not be easy to push the collars back into the metal frame's holes later, when you reinstall the panel. You may find that some of the collars get pushed out entirely and fall off. Or you may find that it is difficult to put the panel back in place, or may mangle some collars by spreading their prongs wide. (If they don't want to pass through the holes and you push too hard.)
So I prefer to remove all the collars -- either at the same time when I remove the pins, or after I have taken off the panel. I only put them in again when reinstalling the panel, pushing them through panel and frame at the same time. (If the prongs are spread wide, I squeeze them closer with my fingers before inserting the collar.) Then push in the pin to secure the rivet.
Posted : 11/12/2025 6:24 am
NickAtNight
(@nickatnight)
You might need to find a new link - the R3045 is not available on that link. How about this one R3045 ?  Same rivet?
     Cap diameter 4.2 mm (A).     Rod Diameter M3 (3mm) (D)     Board hole diameter 3.1 mm.   Length 6.1 mm (E)
     Cap thickness 1.2 mm (B).     Rod Length 4.5 mm (L)                Board Thickness.  2.0-3.0 mm
Posted : 12/12/2025 11:01 pm
NickAtNight
(@nickatnight)
The pins are probably best used once and done?    A replacement pack off 55 rivets is available from PRUSA for $11.99. (Nylon Rivet 3.1 x 4.5 - 55 pc)
Posted : 12/12/2025 11:03 pm
NickAtNight
(@nickatnight)
I don't see how the pins would wear out at all. They only slide in and out of the Nylon color and don't see any sharp edges, hence there should be no wear and tear.
Early on I have mangled a couple of the collars when re-assembling a panel with the collars still inserted, by spreading their prongs wide instead of pushing them through the frame profile hole. I have not reused those because I felt the material might weaken too much if I try and bend them back into shape. But by pulling out the collars and only re-inserting them through both, panel and frame, during assembly, I can reliably avoid that problem and have re-used all rivets since.
Posted : 13/12/2025 7:01 am
rib242
(@rib242)
I use neodymium magnets instead of the rivets on parts of the case I need to remove quite often, as the top.
Works very well!
Posted : 15/12/2025 2:28 pm
Dr. Skycat
(@dr-skycat)
Earlier this week I got a message from "Elmo" about my  post (Posted : 10/12/2025) entitled "Drill and Tap for M4-07 Torx screw"
He asked me ""Hello, how did the rigid mounting work for you? What length of screw did you use?"
For some reason I was NOT able to reply as I was blocked by Prusa.
So I'm attempting to answer Elmo this way here. The screw it a M4-07 Torx as mentioned in my post.
This has worked out great for me as I have experienced many Core One issues that resulted in having to remove and replace both side covers many times.   One point ... I never did anything to the top plastic cover as it seems quite ok to just let it sit there by gravity.
One person had commented that he would never trust screws holding in thin sheet metal.  The entire metal frame of the Prusa Core one is thin sheet metal that is held together by  screws and tapped holes .
Posted : 08/04/2026 5:08 pm
Conrad
(@conrad-2)
I bought a spare bag with my last order from Prusa. Print that tool up above. It works really well and I've yet to break a rivet.
Posted : 08/04/2026 6:48 pm
rib242
(@rib242)
Just use strong magnets, believe me, it is a life saver 🙂
Posted : 08/04/2026 6:51 pm
Posted by: @dr-skycat
That's not correct. At least in my Core One, Prusa has not tapped any threads just into the thin sheet metal frame profiles. There are press-fitted metal inserts (or rings welded to the back?) which carry the threads.
Even in cheap enclosures, the worst I have seen were holes that had been punched out leaving a slight collar, which provided enough depth for a few turns of the thread. But threading an M3 or M4 screw into a plain circular hole in sheet metal is not a good solution.
As Conrad mentioned, the Nylon rivets are fine. Either use the tool suggested above, or just push them out from the inside with your fingers. (Center pin first, then the outer collar.) I have not ordered any extras, since I have not damaged one yet.
Posted : 08/04/2026 7:10 pm
Page 2 / 3
