Any alternative for rivets?
Strona 1 / 2
Erwan
(@erwan-2)
I recently finished to assemble my Core One. I removed the right plate to check something on the filament sensor, and couldn't reuse half of the rivets because they broke. Now I have to remove the left plate to install the camera, and I'm sure to waste a few again.
I know Prusa sent a lot of spares, but at this rate I'll run out sooner or later.
Did anyone found an alternative to those crappy rivets to fix the panel? Something I can remove and put back without "consuming" whatever was keeping the plate in place.
This topic was modified 4 months temu by Erwan
Opublikowany : 13/06/2025 6:47 pm
RE: Any alternative for rivets?
I also initially felt that the plastic rivets were a bit of a botch. But now I quite like them: Easy to install (just from the outside), you can't overtighten them, and they have not caused any rattling panels on my printer.
How did you end up destroying half of the rivets? They are meant to be reusable. You can either push out the locking pin from the inside, or pry it out with a plastic spudger or guitar plectrum from the outside; then pull out the outer piece if it has not already come out together with the pin. Before re-inserting the split outer piece, just make sure to squeeze it together a bit if it is too wide-open.
Opublikowany : 13/06/2025 7:27 pm
Erwan
(@erwan-2)
I think it was when putting them back. I'll try what you're saying about pulling the outer piece out before reinserting, maybe that was the issue.
Opublikowany : 13/06/2025 9:07 pm
BMC
 BMC
(@bmc)
I may create TPU rubber-like rivets... or rubbets. I think I'll call them Bunny Rubbets. - Anyway, the stock rivets are awful as with having to remove them to do maintenance. I'm thinking about creating TPU "hinges" and TPU snap latches on the side plate above the filament. This way I can just pop it open a tinker around without fiddling with the rivets.
Opublikowany : 18/06/2025 4:58 pm
1 ludzie polubili
Posted by: @bmc
I am not sure whether I am correctly envisioning what you have in mind. But if I do, you might find that they should better be called 'rattlets'. 😉
Opublikowany : 18/06/2025 6:27 pm
1 ludzie polubili
Erwan
(@erwan-2)
OK I think I kinda get it, they broke because they were too "open" when I tried to put them back. You do have to squeeze them before reinsterting, but it's pretty annoying because they never get as tight as when they're new and you have to be extra careful when putting them back.
Posted by: @jurgen-7
Opublikowany : 18/06/2025 6:33 pm
Posted by: @erwan-2
Right -- if you try to push the rivets back in while they are too wide open, they won't go into the hole but you rather force the two "jaws" even further apart until they break.
I have not had any problems with re-inserted rivets having a looser fit than originally, and I don't see how that could be the case. They do not rely on elastic force pushing the two jaws apart. Rather, when you push in the locking pin, it will force the jaws apart. So there will again be a positive lock.
Opublikowany : 18/06/2025 6:41 pm
gb160
(@gb160)
I think the rivets are a great idea. There’s a knack to taking them out and putting them back. I can get the top off in seconds, they’re the only ones I’ve needed touch.
Ive never broken one…although I’ve pinged a few across the room though.
Opublikowany : 18/06/2025 7:05 pm
1 ludzie polubili
Erwan
(@erwan-2)
Sorry I don't mean that they have a looser fit - when they're inserted again, they're fine.
It's just that you can't never really get them closed enough to be as easy to insert as a new one.
Opublikowany : 18/06/2025 7:09 pm
1 ludzie polubili
Raaz
 Raaz
(@raaz-2)
Posted by: @erwan-2
I agree. With freshly cut nails, I needed to use my my little black tweezers to keep them tight, while inserting.
Opublikowany : 18/06/2025 7:59 pm
derekp7
(@derekp7)
Pull the pin out, and push the outer part of the rivet in first.  Then follow it with the pin, and all is good.
Opublikowany : 15/07/2025 7:02 pm
TeamD3dp
(@teamd3dp)
Before receiving my conversion I was reading all of the gripes about broken rivets and expected them to be an annoyance.  They have turned out to be extremely convenient, and so far reliable.  Being able to pop a side panel off of the printer in about a minute without tools is pretty awesome.  As stated above a little bit of care is needed when re-inserting the sleeves.
I left the top completely loose until yesterday when I needed to print at a high chamber temp and the top acrylic was starting to bow a bit when heated from below.  So I popped 4 rivets in to keep it flat and they'll stay there until I'm done with this high temp printing. 🙂
-J
Opublikowany : 24/07/2025 1:40 pm
2 ludzie polubili
zapta
(@zapta)
Any idea where to purchase spare rivets?
Opublikowany : 24/07/2025 8:42 pm
Steve
(@steve-5)
Nylon Rivet 3,1x4,5 - 55 pcs
Opublikowany : 24/07/2025 11:30 pm
zapta
(@zapta)
Posted by: @steve-5
Thanks!   Based the table below from Ali Express, I believe that they are R3045, like the ones here https://www.aliexpress.us/item/3256806157115692.html
BTW, if I got it correctly, when lifting the CORE One by its handles, the printer is hanging on the plastic rivets that hold the side panels. That's scary.
Opublikowany : 24/07/2025 11:53 pm
2 ludzie polubili
Posted by: @zapta
Try shearing even a single rivet off (when installed like it is in the Core One). Nylon is quite a tough material!
But yes, it's probably a good idea to actually install all the rivets which hold the side panels, not only to avoid rattling.
Opublikowany : 25/07/2025 4:29 am
1 ludzie polubili
zapta
(@zapta)
Posted by: @erwan-2
..Now I have to remove the left plate to install the camera, and I'm sure to waste a few again.
Try this tool, it removes the inner pin without damaging it and then just pull out the outer sleeve. When you put it back in you may need to press a little the split end of the sleeve to fit it inside the hole.
https://www.printables.com/model/1367997-prusa-core-one-rivet-extraction-tool
Opublikowany : 28/07/2025 3:46 am
1 ludzie polubili
zapta
(@zapta)
I can confirm that the Chinese reivets type R3045 fit nicely in the CORE One and like the Prusa rivets, they are reusable.
I got the black ones from this vendor but there are others  https://www.aliexpress.us/item/3256806157115692.html   (make sure to select the R3045 option and the color of your choice).
You can also search Aliexpress for Rivets R3045
This post was modified 2 months temu 2 times by zapta
Opublikowany : 02/08/2025 7:24 pm
1 ludzie polubili
mbiasotti
(@mbiasotti)
https://www.mcmaster.com/91020A098/
Opublikowany : 05/08/2025 6:36 pm
PC
 PC
(@pc)
#6 x 3/8" Pan Head Sheetmetal screws went in my back panel...
Opublikowany : 06/08/2025 12:06 pm
Strona 1 / 2
