Z Adjust Mini+
My nozzle adjust height is now -2 above the heatbed. That is the max distance. How can I decrease this distance, understanding that the nozzle still prints correctly ?
RE: Z Adjust Mini+
This has been covered here in forum many times in last couple of weeks. In short:
Pull up PINDA sensor for about a 0.5-1.0mm. That is, height difference betwen bottom of PINDA sensor and the tip of the nozzle should be about 1-1,5mm.
After that you must do fresh first layer calibration -starting with 0 (default) Z-offset!
[Mini+] [MK3S+BEAR]
RE: Z Adjust Mini+
Instructions for adjusting the PINDA are in Step 16 of https://help.prusa3d.com/en/guide/how-to-replace-superpinda-mini-mini_179912
I put this little helper on Prusaprinters.org to help position the SPINDA: https://www.prusaprinters.org/prints/57192-spinda-height-adjustment-tool-mounts-into-3030-ext. Works better than zip ties or credit cards, which have less well-defined heights.
For an illustration of relationship of distance of PINDA to nozzle and sheet, see
Z Adjust Mini+
Hi
Procedure also described in Prusa assy manual https://help.prusa3d.com/en/guide/7-preflight-check_204705#204713
Did it jut after receiving my MINI+and no more pb whatever plate used
JC
Prusa MINI+ at home / Prusa MK3S+ in the Fab Lab / You can have a look at my designs here printables.com
Thanks for range
Mine is close to bumping the allowable limit at -1.850 mm. I am going to leave it as is and see how it goes.
Thanks to @BogdanH and @fuchsr for giving the specific range in case I decide to adjust the Pinda. I like real numbers vs. a credit card thickness!
