					                		Rigid mount for mini (or mini inside a portable enclosure) - User mods - OctoPrint, enclosures, nozzles, ...                                    </title>
                <link>https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/rigid-mount-for-mini-or-mini-inside-a-portable-enclosure/</link>
                <lastBuildDate>Wed, 15 Apr 2026 04:57:56 +0000</lastBuildDate>
                        <title>RE: Rigid mount for mini (or mini inside a portable enclosure)</title>
                        <link>https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/rigid-mount-for-mini-or-mini-inside-a-portable-enclosure/#post-423313</link>
                        <pubDate>Sun, 25 Apr 2021 10:11:41 +0000</pubDate>
                        <description><![CDATA[I have about a similar thought.I have an 18mm laminated board (think cuttingboard) and mounting the mini on that with some L-brackets to stop it moving around.I was thinking having the roll ...]]></description>
                        <content:encoded><![CDATA[<p>I have about a similar thought.</p><p>I have an 18mm laminated board (think cuttingboard) and mounting the mini on that with some L-brackets to stop it moving around.</p><p>I was thinking having the roll either inside on right side, outside on right side or on the back side.</p><p>Simple ptfe-thruput if placed outside, some sort of pulley(think 3d-printed version of swivel pulley used on boats)</p><p>to always make it feed into the sensor/extruder at right angle.</p><p> </p><p>I was thinking of a 2020 extrusion frame with a latch for the board so i can pull out the printer for easy maintenence.</p><p>If the frame is sturdy the sides doesn't need to be anything else then for isolation (a few layers cardboard insulates good, cheap and replaceable).</p><p>On the other side, a wood frame and sides makes good too. Cheap, simple, no special tools or fasteners but can move/warp depending on humidity and heat. Minor problem if printer is mounted on a separate plate inside so it doesnt move with the frame.</p><p>I'm thinking also slot for extra printsheet, some tools etc inside. A grab'n'go box.</p><p> </p><p>I know, i know. I'm usually overthinking and extreme overengineer things i build.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/">User mods - OctoPrint, enclosures, nozzles, ...</category>                        <dc:creator>mrstoned</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/rigid-mount-for-mini-or-mini-inside-a-portable-enclosure/#post-423313</guid>
                        <link>https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/rigid-mount-for-mini-or-mini-inside-a-portable-enclosure/#post-423040</link>
                        <pubDate>Sat, 24 Apr 2021 20:34:34 +0000</pubDate>
                        <description><![CDATA[@mrstonedI received my Mini last week and I&#039;m also thinking about building a portable enclosure for protection and transport. Thought I&#039;ll join this discussion and throw my ideas into the pi...]]></description>
                        <content:encoded><![CDATA[<p>@mrstoned</p><p>I received my Mini last week and I'm also thinking about building a portable enclosure for protection and transport. Thought I'll join this discussion and throw my ideas into the pit. </p><p>My idea ist to get a rigid baseplate (+15mm plywood) to mount the printer onto (flexible or rigid).  With the cover I think about a removable hood made from 8mm plywood with window-cutouts, that is attached with hooks (similar to the ones used with flightcases) . For full access you'll be able to remove the complete hood. A build in front door gives access to operate the printer. Dimensions of around 45x45x45 cm. Filamentspool placed on top, being inserted through a hole in the top or right side. Other possible features may be carbon scrubbers, led strips, and so on.</p><p>What do you think? What does your approach look like?</p><p> </p><p>Best regards</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/">User mods - OctoPrint, enclosures, nozzles, ...</category>                        <dc:creator>waschbaermann</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/rigid-mount-for-mini-or-mini-inside-a-portable-enclosure/#post-423040</guid>
                        <link>https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/rigid-mount-for-mini-or-mini-inside-a-portable-enclosure/#post-420244</link>
                        <pubDate>Tue, 20 Apr 2021 12:36:10 +0000</pubDate>
                        <description><![CDATA[Yes i&#039;ve seen handles on the mini before, among others 3DPrintingNerd&#039;s videos.My inside kinda screamed when he picked it up by the handle :)My worries is to not skew/bend it while moving it...]]></description>
                        <content:encoded><![CDATA[<p>Yes i've seen handles on the mini before, among others 3DPrintingNerd's videos.</p><p>My inside kinda screamed when he picked it up by the handle :)</p><p>My worries is to not skew/bend it while moving it.</p><p>My original idea came from finding this type; https://www.thingiverse.com/thing:14514</p><p>(I was actually researching a portable Raspberry Pi field case-solution but that's another story).</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/rigid-mount-for-mini-or-mini-inside-a-portable-enclosure/#post-420244</guid>
                        <link>https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/rigid-mount-for-mini-or-mini-inside-a-portable-enclosure/#post-420202</link>
                        <pubDate>Tue, 20 Apr 2021 11:55:25 +0000</pubDate>
                        <description><![CDATA[Interesting idea. In practice though I&#039;m not sure how necessary/useful it would be. I have mine in LACK enclosures to address the safety and dust protection issue. And by itself the Mini is ...]]></description>
                        <content:encoded><![CDATA[<p>Interesting idea. In practice though I'm not sure how necessary/useful it would be. I have mine in LACK enclosures to address the safety and dust protection issue. And by itself the Mini is might portable anyway, especially with Matt's handle: https://www.prusaprinters.org/prints/14610-prusa-mini-handle.</p><p>In any case, I'm looking forward to others' feedback on this idea. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/">User mods - OctoPrint, enclosures, nozzles, ...</category>                        <dc:creator>FoxRun3D</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/rigid-mount-for-mini-or-mini-inside-a-portable-enclosure/#post-420202</guid>
                        <title>Rigid mount for mini (or mini inside a portable enclosure)</title>
                        <link>https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/rigid-mount-for-mini-or-mini-inside-a-portable-enclosure/#post-420178</link>
                        <pubDate>Tue, 20 Apr 2021 11:17:22 +0000</pubDate>
                        <description><![CDATA[I wonder how the mini would react to being mounted rigidly to a base board with a brace for the Z-axis inside a portable frame.And if so the board should be mounted rigid or flex against the...]]></description>
                        <content:encoded><![CDATA[<p>I wonder how the mini would react to being mounted rigidly to a base board with a brace for the Z-axis inside a portable frame.</p><p>And if so the board should be mounted rigid or flex against the enclosure-frame.</p><p> </p><p>My idea was two-fold, enclose the printer for both safety (no fingers poking inside) and draftfree printing.</p><p>And the ease of relocating the printer to where it is needed (on the go, mobile site, show and tell, etc).</p><p> </p><p>My printer will most likely show up end of this week or beginning next week (got shipping notice today but not left prusa yet).</p><p>Thoughtpattern similar to how the frame of MK3 is, and you can grab it on the top without risking bending anything inside the printer.</p><p>Discussions, ideas, tips, already built ones are very welcome.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/rigid-mount-for-mini-or-mini-inside-a-portable-enclosure/#post-420178</guid>
