Push fittings - Capricorn PTFE
Has anyone installed new PTFE tube - what about Push Fittings? Im having issues with under-extrution and the fillament does'nt go smooth in the original tube...
RE: Push fittings - Capricorn PTFE
I've done it, look here: https://www.prusaprinters.org/prints/30001-prusa-mini-pc4-m6-bowden-fitting-adapter
Nice - and has it done underextrution better?
Hard to tell, because it was part of a bigger update: I've also added a Bondtech extruder and heat-break 😁.
Underextrusion you can regulate in the Slicer Software:
Value 1 is default. A reduction in the value reduces the filament flow and vice versa.
