Prusa Mini Silicone Bed Leveling Mod
Strona 6 / 21
Arklan
(@arklan)
RE: Prusa Mini Silicone Bed Leveling Mod
@straylit
ya know, i'd looked over that and ignored it previously but you have an excellent point. printing that now.
Opublikowany : 08/10/2020 12:37 am
1 ludzie polubili
straylit
(@straylit)
Posted by: @straylit
McMaster-Carr:
5041K732  Hi-Temp Silicone Rubber Tubing for Air&Water Durometer 70A, Opaque Black, 3 mm ID, 7 mm OD, 5 ft. Length
90236A123  Zinc-Plated Alloy Steel Torx Flat Head Screws, M3 x 0.5 Mm Thread Size, 16 Mm Long, Pack of 50
Amazon:
B003Z6VHE4 Axial AXA1052 Thin Nylon Locking Hex Nut (10-Piece), M3, Black
The mod went smoothly and looks amazing with the black tube/nuts!
Appears so clean that I'm surprised it doesn't ship this way from the factory.
My deviations are all at ±0.01 or 0 and YACS came in at 141.20x141.22.
Until we can upgrade to PINDA/temperature-compensation I think this is as good as it gets because we are within the margin of error for the MINDA.
Print a substantial M3 wrench first! I had to tape mine to a metal wrench to keep it from flexing during the initial compression.
I'm not quite sure which way the locknuts should be oriented, I placed them in the direction which seemed natural but I notice that the nylon insert is not fully engaged as screws I used did not protrude past the locknut.
Opublikowany : 11/10/2020 7:13 pm
GaetanLE
(@gaetanle)
After not being able to print for over a week (out of nowhere my nozzle would crash into my prints and move them) I installed the mod and voilà - today I can print again - lucky me I printed it before the problems came out.
One the other side I'm still clueless what caused all of this but well, now it seems I'm back.
Opublikowany : 11/10/2020 10:03 pm
WillDeed
(@willdeed)
@arklan-uthoslin
I found the same torx screws on Amazon (along with the super slow shipping...)
I'm assuming you've received yours by now and have a ton of extras. If you live in the US and would be willing to ship some, I'd be willing to buy some from you. DM me if interested.
Opublikowany : 15/10/2020 5:41 am
Arklan
(@arklan)
Posted by: @willdeed
@arklan-uthoslin
correct. however i've already passed my extras on to a couple other guys in this thread, back on page five.
Opublikowany : 15/10/2020 5:33 pm
Jim
 Jim
(@jim)
@willdeed
See above, but if you are interested I have the whole kit of parts for $6.00+shipping (some of the torx came from Arklan).
-Jim
Opublikowany : 15/10/2020 5:45 pm
WillDeed
(@willdeed)
@mcjamez
Yeah, I'm interested, but I'm still too new to send a DM. Are you able to DM me for details?
Opublikowany : 15/10/2020 6:02 pm
1 ludzie polubili
Arklan
(@arklan)
Posted by: @mcjamez
@willdeed
-Jim
that's the guy i sold my stuff to, so there's my torx screws for ya! 😀
Opublikowany : 15/10/2020 11:59 pm
1 ludzie polubili
Jim
 Jim
(@jim)
@mcjamez
DM sent, we should be able to DM back and forth now.
Opublikowany : 16/10/2020 1:26 am
WillDeed
(@willdeed)
Posted by: @mcjamez
@mcjamez
I got your DM, but it looks like I can't reply to that either. I thought I might be able to to reply to the email that was sent, but that goes to a "no reply" address... *sigh*
It sounds like 5 moderated forum posts is what's needed to become an Active Member, so hoping this will "flip the switch".
Opublikowany : 16/10/2020 4:08 am
@willdeed
Hi WIll,
Your Switch should be Flipped now!
Opublikowany : 16/10/2020 10:59 am
1 ludzie polubili
Zbyněk Ch.
(@zbynek-ch)
Hi guys,
I've created simple jig to help you sanding standard M3 locknuts. Half an hour printing, five minutes sanding. No need to look for low profile locknuts.
https://www.prusaprinters.org/prints/43563-prusa-mini-silicone-bed-leveling-mod-locknut-sandi
Happy sanding!
Opublikowany : 16/10/2020 2:51 pm
1 ludzie polubili
Zbyněk Ch.
(@zbynek-ch)
Hi again,
so my SiliMod is finally installed. Thanks @benji and others who contributed.
Here goes another jig to help with this install:
https://www.prusaprinters.org/prints/43629-prusa-mini-silicone-bed-leveling-mod-bed-tightenin
My thoughts and reccomendations:
1) I didn't use new 16mm screw in the center hole, just reused original
2) use 18mm screws even if you manage to get low profile nuts, it is MUCH easier to catch the screw threads
3) in my opinion only 18mm screws and full size locknuts are necessary, you simply sand the rear middle one down in a few minutes, no headaches
4) first I tried to level the bed using values from OctoPrint BedVisualiser plugin - not a good idea, Benjis new tool https://bbbenji.github.io/PMSBLM/ is much better
5) in new Benjis tool results are displayed naturally, as you are standing in front of the printer, so top right value is for the screw next to heatbed powercable
Opublikowany : 17/10/2020 4:19 pm
Adam_pres
(@adam_pres)
Great mod, sorted my first layer issues. Does any one else have readjust the screws when they change from the textured sheet to smooth sheet?
Any one else have this problem?
Opublikowany : 25/10/2020 1:30 pm
frankyp
(@frankyp)
@mcjamez
Hello Jim. I tried sending you a DM but it wouldn’t let me, possibly because I’m new here. How do I get in contact with you for a leveling kit that you offer?
Thanks,
Frank
Opublikowany : 30/10/2020 8:30 pm
GaetanLE
(@gaetanle)
Hey @adam_pres3 I don't have to, you have to change your z height actually! The textured sheet is about 400 micron lower than the smooth one.
Sadly you can't store the value on the Mini.
Opublikowany : 30/10/2020 9:00 pm
WillDeed
(@willdeed)
  1. Make sure your X-Z assembly is square with the Y assembly. If you can't get it right, try shimming.
Is there a guide for doing this? Both checking/adjusting for squareness and shimming.
The only thing I've found is this link, which doesn't seem like the same thing.
Opublikowany : 31/10/2020 6:49 am
vARCHAR_oRANGE
(@varchar_orange)
Just finished up without any real issues. However, how do you get the MeshMap to work in Octoprint? Ran it and it just performs G28 then sits there, nothing else happens...no issues running it on my Bear and MK3S so no clue what I'm doing wrong!
Opublikowany : 31/10/2020 3:27 pm
@patrick-c8
My code for the PrusaMeshMap Plugin:
G80 ; mesh bed leveling
G81 ; check mesh leveling results
G1 Z10 F8000
G1 X185 Y160
maybe you try this.
Opublikowany : 31/10/2020 3:51 pm
WillDeed
(@willdeed)
Just finished this mod and pretty pleased with it. Thanks for sharing!
Before:
After:
I have left over parts (at least enough to form one full kit), so if anybody is looking for parts DM me.
Opublikowany : 31/10/2020 9:12 pm
Strona 6 / 21
