Prusa Mini and Octoprint
Página 5 / 5
mm_designer
(@mm_designer)
RE: Prusa Mini and Octoprint
I have the same issue?
Respondido : 22/02/2022 11:19 am
towlerg
(@towlerg)
As pointed out above, Octoprint should not affect print quality.It simply streams the output to the printer.
The only place that vanilla Octoprint adds GCode is in "Octoprint settings/GCode scripts". Which by default a probably blank.
Esta publicación ha sido modificada el hace 4 years por towlerg
Respondido : 22/02/2022 1:31 pm
Chris Laudermilk
(@chris-laudermilk)
Posted by: @towlerg
There are several scripts. After print job completes and after print job is cancelled have some code, the others start blank.
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
Respondido : 22/02/2022 2:47 pm
kevman
(@kevman)
So in the spirit of sharing information, I wanted to mention an issue I had. I switched my hotend from a Mosquito to a REvo Micro, the mosquito was offset from the orignal hotend by a few mm so I had custom G-code to address that. The Revo sits at the same place as the stock hotend so I removed that g-code, but was getting some issues with the purge line being printed outside the bed. Turns out I didn't have the custom bound box defined. I am in Mid print right now , but will test after . I assume it should resolve that problem ? Also I was not getting any warnings at all, is that something that changed in the firmware ?
Respondido : 28/02/2022 5:24 pm
kevman
(@kevman)
Looks like I answered my own question, I disabled the warning about size detection.
Also Prusa documentation suggests -3 / 180 for Y as opposed to -4 which is posted in this thread. Not sure if it matter too much but wanted to point it out.
https://help.prusa3d.com/en/article/octoprint-configuration-and-install_2182/
Respondido : 28/02/2022 5:31 pm
kevman
(@kevman)
so I am completely stumpped. Even with the bound box my prime line doesn't print on the bed. Any ideas ? ?
Respondido : 28/02/2022 7:22 pm
Página 5 / 5
