RE: Prusa Bear Mini Mk3s
Yes it does appear right after seams start for the next line.
I usually try aligned or rear to make things neater, But on either aligned or rear it puts a seam right down the thin side of that bit making it week for me.
If the first layer is good. everything for your settings should work fine. You shouldn´t need to change any retractions or something like that specially if you use Prusament on a Prusa.
Try painted seams so you can move away from that part if it make problems for you
ok cool I will try that thanks 🙂 , but still kinda still bugs me as other people don';t have to do that for this part.
yeah first layers are great It's so annoying because other people have a great time with petg and mini and I feel kinda frustrated by it all lol
I can't send it back to prague / prusa either its not worth the cost and the long long time it would take, and they couldn't help me solve it on online chat 🙁
Here is a quick video showing how other bits are nice and solid but this bit is soft.
Uploaded a thicker part for you. I don´t think that change your real problem but maybe if you build your MINI-Bear you can reprint things that wasn´t good.
You are not gonna miss it 🙂 MINI Bear Remix and Spoolholder and Filament feeder by Tomson | Download free STL model | PrusaPrinters
Oh that part around the heatbrake! I thought you said it was the hook that was brittle?
That part is OEM. Have not change anything with that.
you are awesome dude 😍 😍 😍
Thanks man
So when I get the bear all setup I hope to not have these stupid issues anyway 🤣
no the hook is fine.. its the thin blade that sticks up that is very soft liek in the video.
Ok. I make a new one, wait a minute
I deleted the last one and uploaded a new one. That cover is 0,8mm thicker downwards. But check so that is not to close to the heatblock ok.
cool thanks man 🙂
Ok @tomson going to print it right now!!
Maybe I should have just gone for your Mirrored Mk3 extruder. you are liking it yes?
This is a mirrored Mk3 extruder. You mean the Hurricane? Yes that one is optimized for the MINI-Bear 🙂 Especially if you use the new fan shroud and use 40x20 Noctua on both. So quiet. But I have not had time to fix 5V hotend power supply. I'm still using a power supply from a cell phone. Works great but it is better if it follows the printer on / off.
Recently I made a laptop mount for VESA and put 3 Noctua fans as cooling and I control it with a fan controller from Noctua. I'm thinking of testing and operating the fan with one and just taking the fan control from the Buddyboard. NA-FC1 (noctua.at)
Can upload the laptop mount if any interest.
wowo you really do some awesome work tomson, Yes sorry I did mean the hurricane 🙂
At first I will just get up and running with a stock mirrored mk3 direct drive on the mini bear so I can keep things as simple as possible, then after a while I will certainly upgrade the hotend and no doubt it will be to whatever project you are currently working on 😀
maybe some kind of new E3d unit or whatever is out then, i see their new ranges like revo etc are meant to be drop in replacements for v6 setups 🙂
Yes i looked at REVO but i let it be on the market for now and see the reviews on it first. But i looked at Phaetus Dragon little. I like the design. https://blackfrog.pl/phaetus-dragon-175-mm-standard-flow-hot-end-p-1992.html
Oh man that phaetus dragin is one sexy bit of kit, it's such a shame to hide it away covered in plastic and fans 🤣
I thought I'd have a quick look on youtube at mk3 extruder assembly videos and..
Check this out @tomson just the bit we have been talking about being thin and flimsy!!, 1min 15seconds
would this part work for me then or would it need mirroring?
ooooh yeah, seems like a few changes to the Extruder now as per https://www.prusaprinters.org/prints/57217-i3-mk3s-printable-parts/files
the extruder cover looks much better and sturdy also so does the fan shroud, so i can just mirror these parts and use them or?
