Prusa Bear Mini Mk3s
Strona 11 / 22
JayMac
(@jaymac)
Nice
Thanks man
Loaded it up and had a look, all looks great 🙂
One silly thing..  can we make it display the mini bed board graphic in prusa slicer? 🤣
Merry christmas to you also!
Opublikowany : 23/12/2021 2:15 am
Tomson Design
(@tomson-design)
RE: Prusa Bear Mini Mk3s
Not shore what you mean but if you mean you can see what you going to print in the MINI-lcd you can with the V2 INI version.
Opublikowany : 23/12/2021 3:22 am
JayMac
(@jaymac)
what I mean is, when i open prusa slicer it looks like this with the prusa ,mini build plate:
And after I import the new v2 .ini file it looks like this:
can i make the v2 .ini file look like the first pic with the mini build plate.
Hope you understand? 😆
Opublikowany : 23/12/2021 3:29 am
Tomson Design
(@tomson-design)
Ok. No it should not like that. The build plate should be OEM as in the first picture.
Opublikowany : 23/12/2021 1:10 pm
JayMac
(@jaymac)
oh so i wonder why it changes like that for me when i load the custom .ini file 🙁
Opublikowany : 23/12/2021 2:05 pm
Tomson Design
(@tomson-design)
I feel comfortable in mechanical design/engineering but software is not my strong suit. I'm sorry but i can´t help you with this. But i believe    it´s plenty of people here to help you. Ask pear.3d .
Opublikowany : 23/12/2021 2:26 pm
1 ludzie polubili
JayMac
(@jaymac)
Yep thanks @tomson
@pear3d.ch any ideas why this is happening? 🙂
Opublikowany : 23/12/2021 2:31 pm
JayMac
(@jaymac)
Hi all
Merry christmas to you all.
I have a big problem lol!!!
i'm just doing the bear mod now, a fun christmas project I thought :(,
got the mini bear frame, all parts ready to go, building it up, i make up the X axis but the smooth rods are not wide enough??
Do we need to use mk3s+ smooth x rods? The frame is the exact same size as has been listed by @pear3d.ch and @tomson so I'm really confused!
Thanks
Opublikowany : 25/12/2021 6:12 pm
MysDawg
(@mysdawg)
@jmac Merry Christmas.
OH NO... I hope there is an easy, quick solution.
Opublikowany : 25/12/2021 8:01 pm
1 ludzie polubili
JayMac
(@jaymac)
Thanks and merrys christmas @MysDawg 😋
I looked back through the thread and the only reference I found was tomson saying "X axis is a little short, add about 10mm spacer".
I would rather just cut a length on 8mm bar to the exact size needed so i can sit it firmly in place the way it should be.
I was going to use 8mm rods for the Z axis, but now i will use them for the X axis and cut them to the correct size,  I will reuse my old 100mm rods for the Z axis.
But what exact size should the X axis rods be cut to for a bear mini? I mean they have to be dead on don't they? or you will have binding issues etc.
Opublikowany : 25/12/2021 8:22 pm
Tomson Design
(@tomson-design)
Hi jmac.
My first build i use the OEM and spacers but in the last build i cut Mk3 rods to 299mm. The space is 300mm but i wanted guaranty it would fit. I´m pretty shore we talked about it before 🙂
Posted by: @jmac
Opublikowany : 25/12/2021 11:43 pm
1 ludzie polubili
JayMac
(@jaymac)
Hi @tomson
Hope you had a great day 😍
Ok cool so tomorrow I shall cut some 8mm rod down to 299 / 300mm. I would love to do it right now but I don't think the neighbours would enjoy the noise at this time 🤣
I Put the original mini 10mm Z rods on and cut them to length, so the left over 8mm rods that I was going to use will be my new X rods!
Hopefully some good progress tomorrow 🙂
Opublikowany : 26/12/2021 12:25 am
Tomson Design
(@tomson-design)
Hi jmac we celebrate on 24 here in Europe but i had a great day with my family. Hope you have had great day as well.
It is good that you are showing respect to your neighbors 🙂
Well if you gonna cut these one you need to start to print the X-axis alternative if you not already printed them 🙂
Good luck with your build.
This post was modified 4 years temu by Tomson Design
Opublikowany : 26/12/2021 12:37 am
JayMac
(@jaymac)
oh no... what alternative? lol - I have no printer right now, the only I have is this one lol.
I printed these: https://www.prusaprinters.org/prints/64032-mini-bear-remixsmokistylewith-alternative-z-rod
and thats what is fitted in the above picture waiting for the 8mm x rods to be cut, this is correct or are you talking about different alternatives?
thanks
Opublikowany : 26/12/2021 12:44 am
Tomson Design
(@tomson-design)
🙂 No if you have them already you are fine 🙂
Opublikowany : 26/12/2021 12:54 am
1 ludzie polubili
JayMac
(@jaymac)
phewwww 🤣 🤣
Have a good night mate ❤️
Opublikowany : 26/12/2021 12:56 am
JayMac
(@jaymac)
All sorted now, 2 rods cut to 299.5mm 😍
I'm so glad I decided to order 2 extra 8mm rods!
Opublikowany : 26/12/2021 3:10 pm
MysDawg
(@mysdawg)
Looks great.
Opublikowany : 26/12/2021 3:16 pm
1 ludzie polubili
JayMac
(@jaymac)
Thanks 😍
Opublikowany : 26/12/2021 3:27 pm
JayMac
(@jaymac)
I figured out why the bed was not showing the mini bed, its because on the .ini file it is pointing to an image file for the bed from c / program files on a windows pc, And i was looking at this on my Macbook.
So I just needed to change the location of where it searches for the images.
It works fine as expected on my Windows desktop PC 🙂
This is where the settings are if anyone needs them:
Opublikowany : 26/12/2021 3:30 pm
Strona 11 / 22
