Prusa Bear Mini Mk3s
Página 1 / 22
pear3d.ch
(@pear3d-ch)
hi guys this is our mod prusa mini bear smokystyle check it at this link:. https://www.prusaprinters.org/prints/37939-prusa-bear-mk3s-mini-ultra-upgraded.          Cheers and happy printing. It prints better than mk3s and way better than Mini. We are  glad to share.
Respondido : 10/08/2020 9:31 am
Benji
(@benji)
RE: Prusa Bear Mini Mk3s
Great work! I will be following this project closely. Please publish to Github.
Esta publicación ha sido modificada el hace 4 years por Benji
Prusa Mini Silicone Bed Leveling Mod: https://bbbenji.github.io/PMSBLM/
Respondido : 10/08/2020 6:02 pm
pear3d.ch
(@pear3d-ch)
Hi @benji,
We did initiated a Github on this matter as you have requested here is the link : https://github.com/3DPGVA/Prusa-Bear-MK3S-MINI---Ultra-Upgraded-
we will try to update it, since there are more mods to come for the MINI 😉
Cheers
Respondido : 10/08/2020 7:39 pm
Cashew92ftw y me gusta
Benji
(@benji)
@3dpgva
Perfect, I hope to contribute.
Respondido : 10/08/2020 8:01 pm
pear3d.ch me gusta
pear3d.ch
(@pear3d-ch)
We ordered some 3030 aluminium extrusions to do the other version the haribo upgrade, what would be fun to use the extruder gears for the directdrive we will post soon a work in progres using the mk3s e-axis directrive with the mini gears. lol a lot to do 😉
Respondido : 10/08/2020 8:08 pm
Benji
(@benji)
@3dpgva
Why are you guys working on several different versions instead of picking one and eventually improving that one?
Are there different pros a cons to each?
Respondido : 10/08/2020 8:14 pm
pear3d.ch me gusta
pear3d.ch
(@pear3d-ch)
Yes there are, the haribo would cost cheaper les aluminum to buy, but we will make the haribo one as well and compare the costs, now to print the front and back plate for the haribo mini you will need a larger bed than mini thats the downside.
Respondido : 10/08/2020 9:06 pm
padigree
(@padigree)
Have you guys ever completed this project? Love my mk3s bear - also thought about upgrading a mini as fun project. Would be glad to see this little monster in action 😉
It’s better to give than to receive. Especially advice.
Respondido : 20/12/2020 8:40 pm
pear3d.ch
(@pear3d-ch)
Hi Padigree, yes we have been using for our printing farm 10 of these mini babies and they do perform at our acceptance, bear in mind this is not Prusa official mini, its a modified one and we dont take responsability, so if you need help on building it let is know we are glad to help you 😉
Respondido : 13/01/2021 1:47 pm
padigree
(@padigree)
Thanks for the reply. Yes, I was thinking about building one of these little beauties out of spare parts as a rigid bowden system using Klipper for fast prototyping. I have a spare original hotend and lots of rods from my mk3s and mini misumi upgrades, also lots of motors and bondtech gears, clones and so on. Maybe worth a try 🙂
Respondido : 16/01/2021 8:07 am
Miembro
It is definitely an interesting MOD.  I have two clones that I might mod.
Respondido : 16/01/2021 3:53 pm
padigree
(@padigree)
Draft
I've had some time today to make it look a bit more like it's big brother haha. It's just a draft atm, have definetly to make some more editing to the x axis, all other parts are modded now to fit original mini hardware. So except the extrusion kit you would need a second Z motor. Everything else will fit. Used the 10mm z extrusions, so you'll gain some height. Either I'll buy a China buddy to remove the appendix or I'll make a whole new Klipper based firmware with an skr. Have to order the extrusions soon, also the motor, carriage and heatbed - so I'll give it a try to build a second "mini". I'll definetly stay with my genuine one. Replaced the rods with misumi a few days ago.
Respondido : 16/01/2021 7:43 pm
Alen me gusta
pear3d.ch
(@pear3d-ch)
@padigree
nice one Padigree, but still i dont know why you need to modify when i posted the entire project modified already in the prusa parts?
and in the project the z axis is reversed because an easier cable managment, it prints exactly as an prusa mk3s+, at least the 10 modified minis we have up and runing 24/24 7/7
Respondido : 11/02/2021 3:37 pm
pear3d.ch
(@pear3d-ch)
for those interested the project is here:
and here for the fusion entire project:
https://www.prusaprinters.org/prints/36473-prusa-mini-mk3s-smokistyle-upgrade-bear
Respondido : 11/02/2021 3:40 pm
Javacer
(@javacer)
@3dpgva
Hello!
How you connect two z-axis motor in motherboard?
I undestud, firmware src have multi z-axis motor preset.
You connect in parallels in z-axis controller? Have this controller power for two step-motors?
Respondido : 10/03/2021 7:02 pm
pear3d.ch
(@pear3d-ch)
Hi @javacer
check here:
https://www.prusaprinters.org/prints/56315-dual-z-axis-for-prusa-mini-upgrade
everything is in prusaprinters or in github
Respondido : 11/03/2021 11:56 pm
Tomson Design
(@tomson-design)
You have done a very nice work  3DPGVA. I will follow this project closely and probably make my own. I have already ordered 2040 frameparts bec. of you :). I like my MK3s bec. of the printresult and i like my MINI+ bec. of the 32bit part and this is the perfect mix of both. I have looked a little of the BONDTECH MK3 upgrade with 3:1 ratio. It looks like the BONDTECH have a smaller radius of the gear but also smaller part of the spline area which drives the filament. I don´t mind mod the mechanical pieces but would rather save the software as original as possible. Do you or anyone know the differens. It would be perfect if we only need to change the load/unload filament time and keep the rest software stock. I`m stupid than it comes to software but worked with mechanical parts my hole life.
Keep up the good work 3DPGVA
Regards/Tomson
Respondido : 13/03/2021 12:17 pm
pear3d.ch me gusta
pear3d.ch
(@pear3d-ch)
Hi @tomjansson909, we didnt change any software we use it as it is the mini software only the start GCODE and we can provide the load unload gcodes.
We are glad you like it, if you need help write us here or in the project,
Cheers
Respondido : 13/03/2021 6:23 pm
Tomson Design
(@tomson-design)
@3dpgva
That sounds good. Yes it one of the best mods i seen so far. I have just ordered the frame parts but not decide yet if i gonna use my Mini for the project or buy new parts for it. Do you have any experience of Igus drylin® R linear slide bearing RJUM-01. I will probably build the frame with new linear bearings on the side and with the mod parts regardless. I don´t want to be without the Mini to long and i don´t want to rush the project. I guess it is a good excuse to get one more printer 🙂 '
Cheers
Respondido : 13/03/2021 7:04 pm
pear3d.ch
(@pear3d-ch)
Hi @tomson never had a good experience with the dryline myself i like more the traditional linear rails with ball bearings.
Yeah you can order the parts from prusa as well or find something in internet.
Better to have 2 minis 😉
Cheers
Respondido : 15/03/2021 9:51 pm
Página 1 / 22
