Octoprint Lovers - New Raspberry Pi 3 A+ Case for Prusa Mini
Olef
 Olef
(@olef)
Freshly published, new Raspberry Pi 3 A+ Case for Prusa Mini -
https://www.prusaprinters.org/prints/15862-raspberry-pi-3-a-case-for-prusa-mini
Respondido : 29/12/2019 12:48 pm
2 les gusta
weak
 weak
(@weak)
RE: Octoprint Lovers - New Raspberry Pi 3 A+ Case for Prusa Mini
Nice @olef. Could you maybe provide Fusion 360 (or similar) files too? I'd like to remix it a bit to use threaded M3 inserts instead of nuts.
Respondido : 06/01/2020 6:05 pm
Andrew
(@andrew-22)
Posted by: @olef
Posted by: @weak
Ditto. I would also like to customize this, probably also with threaded brass inserts and maybe alternate mounting options.
STEP or IGES, or the original CAD source would be very helpful. These days it is not enough to just share STL files.
Thanks! Looks like a great design. Otherwise I will need to create my own from scratch.
Respondido : 27/09/2020 6:52 pm
I had thought about using an A+ but having to use a nearby RPi camera module or longer webcam requiring a USB hub was a challenge.
This design would allow the RPi to be positioned close enough for a camera mounted on the X gantry with some strain relief.
Very nice. Thanks for sharing it.
Respondido : 27/09/2020 7:25 pm
Miembro
You should do one for a 4B.
Respondido : 28/09/2020 12:22 am
