Helpful print bed tool
Codetoad
(@codetoad)
This little spatula has been super handy for me, so I thought I'd share. I use it to gently remove small objects from the print bed without having to touch the surface. Skirts, the nozzle prime line, etc. It has rounded edges so it isn't scratching my PEI print bed.
https://www.amazon.com/OXO-Grips-Stainless-Steel-Turner/dp/B00HEZ884E
I'm not affiliated with this thing in any way, and of course your mileage may vary - I just personally find it useful so I thought I'd share.
Postato : 12/06/2020 7:53 pm
jsw
 jsw
(@jsw)
RE: Helpful print bed tool
I ruined the surface of one of the smooth steel sheets using just such a tool! I was able to pry off the print, but with it came a few pieces of the coating.  I now use plastic printed tools, and if one of those gets worn, I just print another.
I learned the hard way that if the print does not want to budge, stop, let it cool, and if needed apply some warm/cold cycles and not use anything metal.
Postato : 12/06/2020 10:18 pm
Posted by: @codetoad
I would rather recommend this printed spatula: spatula
Postato : 12/06/2020 10:47 pm
2 persone hanno apprezzato
Codetoad
(@codetoad)
I got the idea from the Prusa Mini setup video, Josef used a similar tool. In general, I try not to pry prints off with a tool like this or a plastic one. This tool is great for knocking off skirts and wipe lines without having to touch the bed - small items especially.
Postato : 13/06/2020 4:40 am
PGe-10
(@pge-10)
@karl-herbert
Thanks for sharing, this spatular is perfect. Thinking of printing a bunch because I always seem to have to look for mine when I need it
Postato : 15/06/2020 7:22 am
Chocki
(@chocki)
A number of users use this one:
https://www.amazon.co.uk/Plastic-Scraper-Sticker-Remover-Removing/dp/B07P53Q48S/ref=sr_1_21?crid=3BCPJ7HO11NE1&dchild=1&keywords=plastic+razor+blade+scraper&qid=1592212491&sprefix=plastic+raz%2Caps%2C159&sr=8-21
Just do a search for plastic razor.
It matches the printer colour as well, does not scratch and the blades are replaceable.
Postato : 15/06/2020 9:16 am
1 persone hanno apprezzato
Utenti
@chocki
I too prefer the plastic razor blades.
I have bothFOSHIO 2PCS Plastic Razor Scrapers and Razor Scraper with Metal and Plastic Blades.  I have learned that the beds last longer if you avoid metal blades.
Postato : 15/06/2020 9:30 am
Chocki
(@chocki)
Those metal razor blades are actually very useful for using in cutting jigs to cut PTFE tube to length as they are quite thin.
Postato : 15/06/2020 11:10 am
Utenti
@chocki
Thanks.  I will use them for that.
Postato : 15/06/2020 12:07 pm
