Help with Filament Loading Distance - MINI
Changed to v6 hotend on my mini and a different extruder (not bondtech)
Installed llama FW ,altered E steps (134) to extrude 100mm to the correct length and reversed the direction.
Now the length of the PTFE from the nozzle to the extruder gear has changed
I need to alter the loading/unloading distance but cant seem to find or know how I go about this.
Is this more PSlicer based as I can't see anything in the FW to alter.
tia
geode
This might help:
https://help.prusa3d.com/en/article/prusa-specific-g-codes_112173/
https://reprap.org/wiki/G-code#M701:_Load_filament
Appreciated
Thanks for that cwbullet
How is it so far?
How do you like the V6 so far? Mine will be here this week.
V6 Mini
Just finished mine and it's working well, esteps didn't change from bondtech numbers. All i've configured is hotend PID.
Good work!
