[Help wanted] add LED to OctoPrint
Hello folks,
I hope that I write my question in the appropriate section.
My setup:
Prusa mini
Pi 4, 4gb - OctoPi 0.17
For the LED I'm using, it's something generic, with 4 wires (RGB&Ground?)
In order to control the LED stip from the PI I'm using this module
I plugged my pi into the input ports
In octoprint i've added the Enclosure plugin
but from then on I'm stuck
no matter what pins I try, I can't get it to light up
the most I've got is, when the toggle is in the off state, only the red color lights up.
pin #2 & 14 are used for my fan.
from the module ground to #9
VCC - red wire - #11
DIN - green wire - #13
CIN - blue wire - #15
I've also tried other plugin but over there I can't get nothing to work.
I've also tried to follow this guide to no avail.
My end goal is:
When the printer isn't printing, LED are off.
When something is printing, LED are white.
When the printer is finished turns Green.
any help would be much appreciated.
RE: [Help wanted] add LED to OctoPrint
Hello folks,
My setup:
Prusa miniPi 4, 4gb - OctoPi 0.17
My end goal is:
When something is printing, LED are white.When the printer is finished turns Green.
To control the GPIO's there are some very practical tools:
I personally use wiringpi and some selfmade bashscripts to control the enclosure ventilation, light, temperature measurement...
That control module looks like it's expecting 5v inputs based on this description:
Suitable for 5V MCU system, Suitable for Arduino UNO R3 and compatible motherboard
.The Raspberry Pi GPIO outputs are 3.3v. You might need a level converter.
What voltage is your LED strip, are you sure it's 12v? How many LEDs are in the strip and what is the max current output of your 12v supply?
Are you sure those are RGB LED's? If you don't have the data sheets you need to check what you've actually got ... there are a lot of single-colour strips (usually white, for shop-fitting and cabinet lighting) that use the same four-pin connections. Most of them are 12v,some are 5v but if they're specifically designed for another application they could be wired for almost anything..
If they are cuttable strips (scissors marked) they are probably 12V.
12V, it say so on the LED strip.
How many? a lot, about 6 meters of streep.
and now that you mentioned it, my power supply is utterly inadequate.
Ok, Let's try this again.
I've cut the strip down, now it has 24 LEDs, about 25 cm.
I've changed my power supply to 12V 1.5amp. (QC3.0)
should I connect all the wires the same as before?
I'm not sure about RGB, but I'm sure about the R. I definitely saw it lit up in red.
No idea about any other color.
And at the very beginning of the strip, it say 5050-60. so SMD5050?
I can't edit my original post, so here is an update:
I've connected it as follow:
Ground - #9
VCC - #4
Din - #13
Cin - #15
in the plugin, I've changed the output type from Regular io to RGB LED Srip
Now I get consistent results!
I can set color, and it works fine
as long as I only pick red.
So, how can I troubleshoot it?
LED strip of module?
I don't think you want to connect VCC between the Pi and your board, if you are powering the board with 12v then "magic smoke" might result. You do need a common ground though.
Your next problem is that the board you have is expecting 5v signals and the Pi is outputting 3v signals, it MAY work, but it could be intermittent or not work at all.
I'm not familiar with the plugins you are using, but you need to connect the clock in and data in on your board to the Pi pins the plugin uses for Clock out and Data out.
You may find it easier to forget about the Arduino add on board and research ways of connecting your LEDs to the Pi.
I switch the light (230V) with this relais 3.3V over the Pi GPIO's. The whole thing is controlled with wiringpi and a bashscript. So I do the same with the enclosure fans and MK3 power on/off.
Ok, this is turing to be harder than I thought.
I think I should start over,
Dordnung.de seems doable,
as for the Mosfet part, I wish to have a bit more clean solution
could I use a board like this?
https://www.aliexpress.com/item/32714752044.html
If I'll buy three of those, what should the wiring be?
Thanks in advance
Do you this this will do the same job?
@sm26
Is basically the same, only that you can theoretically perform 3 independent GPIO switching processes.
Hi @sm26
How do you control the module? Apparently if you buy it you will receive some arduino code which guides you how to actually control it. It has two control pins (cin, din). It doesn't work by just setting the pins high, it expects some pwm or similiar.
Apart from that it needs 5V on VCC, not 3.3V (no problem, PI has 5V out). The GPIOs only have 3.3V level, but the data inputs probably work with 3.3V as well, but not guaranteed.
Ok, I'm back!
I've got 3 of those:
Each module gets power from DC into VIN & GND
Then V- goes between every module and the strip ground.
V+ goes from each module to one color on the strip.
GPIO17 for red SIG
GPIO22 for green SIG
GPIO24 for blue SIG
And also each module is wired to the Pi ground as well.
VCC is left out for all of them.
how wrong am I?
The LED strip has no permanent GND. It needs permanent +12V while GND is the switched connection. This means one V+ needs to go to the strip +12V and 3 different V- to the R,G,B pads.
I am also pretty sure that your first setup would have worked with the correct code, which would be more elegant than using 3 mosfet boards.
@orkelprint you are right!
now that I've swapped GND and +12V, it works!!
Now for optimization.
From my wall, I use a phone charger to get USB-C, then cable to this little thing. and from there I got power.
that sounds like a double conversion to me...
I found a slimmer 12V 1amp power supply, for my low led count, it seems to work!
Next, we need to print a housing for this mess, a remix I like (of IRF520 mosfet triple holder by brotherchris)
More pictures to follow.
