Filament Flow Sensor?
Anthony Urbani
(@anthony-urbani)
Ive had issues where a Filament spool has tangled (ANNOYING) and the printer has keeped working not knowing that the filament is not flowing (Clogs also)
The Filament Run out helps if you run out easy but want to know if there is still movement on the filament flow
I work as with everyone else does and cant keep an eye on the printer 24/7
I can monitor my printer at work with a live feed of a camera ive setup but again when out in the field there is so much i can do
I can monitor it from time to time via prusa connect but thats it.
Does anyone know of a Filament flow sensor that would somehow alarm if lets say has not detected flow in a minute?
Posted : 09/02/2025 11:22 pm
_KaszpiR_
(@_kaszpir_)
Check out BigTreeTech SFS extension.
But I use just plain kitchen weight and check the spool weight change from time to time.
Posted : 10/02/2025 7:52 am
