Error Message- Firmware in File corrupted/Prusa Mini
Hi. I put my printer together today.
Managed to print the Prusa sign, but when I tried to print the dog, I got an error message 'firmware in the internal flash corrupted.' I hit reset but it then says error mounting USB drive.
It's stuck mid print and even turning it off doesn't fix.
Please help!
RE: Error Message- Firmware in File corrupted/Prusa Mini
Please help!
Hello and welcome to Prusaforum!
Possibly the Prusa USB stick is defective. This is a known and common problem. First try to change the stick. If that doesn't work, I would do a factory reset and reflash the firmware.
https://help.prusa3d.com/en/article/factory-reset-mini_177516
https://help.prusa3d.com/en/article/firmware-updating-mini_124784/
good luck 👍
