Different Hotends
Pagina 15 / 16
Lung
 Lung
(@lung)
RE: Different Hotends
Posted by: @bobstro
Posted by: @lung
Could you measure one of your nozzles from tip to end of the thread please?
Not very precise, but overall length is roughly 12.61mm and thread base to top is 7.4mm. These are wobbly measurements holding the nozzle in my hand. The numbers I'm getting are all very close to the E3D V6 nozzle dimensions.
3D Solex sells them as "i3 Matchless" individually or as a "Prusa i3 nozzle speed doubler" set.
Are these measurements of your standard E3D V6 nozzle or your Solex nozzle?
Here's a photo of my Solex with my V6 Mini nozzle, you can see they're the same length overall but the thread is noticeably shorter on the solex.
Postato : 10/04/2021 6:35 pm
Lung
 Lung
(@lung)
I have just noticed that in the Solex photos of the I3 nozzle found here
there's a gap between the thread and the hex, same as in a proper V6 nozzle. If you look at my photo
there's no gap on my Solex nozzle.
Questo post è stato modificato 5 years fa 2 tempo da Lung
Postato : 10/04/2021 8:26 pm
Utenti
After a few months of fighting stringing, I have found that several other hotends, but especially the V6 on the mini, require more retraction that the stock Mini hotend.
Postato : 22/04/2021 9:42 am
Daniel
(@daniel)
RE: Verschiedene Hotends
@cwbullet
I have the V6 Dragon Hotend and my retraction settings have stayed the same as the original Prusa MINI Hotend, although I was generally 1.6mm previously as the 3.2mm retraction didn't work well for me, but obviously the reduced retraction applies for many and others need more and it probably doesn't matter which extruder is used, there are just too many variables that will affect the end result.
And just for fun try out a retraction for PLA with 1.4 mm, who knows, it might work better for you.
Postato : 22/04/2021 4:03 pm
Utenti
@daniel
I had similar results with the Dragon.  It was 3.2 on the original and 3.2 on the Dragon.  The V6 and a couple of others, my retraction was 4.2.
Postato : 22/04/2021 5:14 pm
Utenti
In particular, the retraction is more essential with PETG.
Postato : 22/04/2021 5:17 pm
Daniel
(@daniel)
With PETG I am only at 1.6 mm, but with a lower retraction speed than with PLA, only standard profile PTEG Prusa MINI.
In the beginning when I was assembling my MINI I just had problems and the prints were terrible even with a retraction of more than 3.2mm. At some point I decided to go with PLA on 1.4mm and it was wonderful.
And there are hardly any threads, of course it also depends on the filament and the layer height.
My setup from the start, where I assembled my MINI:
Bondtech extruder
BondTech heat break
Capricorn PTFE Teflon hose up to the hotend without intermediate piece
Trianglelab T-V6 Plated Copper ruby nozzle
Postato : 22/04/2021 6:09 pm
wes_young
(@wes_young)
Hey Folks! I'm glad I found this thread as I have a Mini+ on the way and I am lurking in case I decide to replace the hot end. I hope I don't need to, but I just wanted to say thank you to all of you for the information that you have collected and provided. I also found this link to a Micro-swiss  mount (might be helpful for anyone that has a spare laying around), though I am leaning toward the V6 if I make a replacement.
https://www.prusaprinters.org/prints/63643-micro-swiss-hotend-mount-v2-for-prusa-mini
Thanks again,
Wesley
Postato : 17/05/2021 6:56 pm
Posted by: @grimmwinters
Hi all, like many of us trying to get this little machine to print decently on a regular level I've grown a little frustrated with the underextrusion problems, most likely being caused by the design of the mini's hotend.
I had blobs of filament under the ptfe-tube in the heatsink even after trying to shove the hotend as far up as possible and so on.
Has anybody used a different hotend like the E3 V6 on a mini yet? Direct drive extruder won't likely be happening due to the cantilever design I guess, because the wait would probably be too much for the x-axis.
Thanks and have a nice day!
I may have mentioned it already, but I've been using an E3D V6 hotend from the MK3 on the Mini for quite some time and am very happy with it. I mainly print ASA Jet black with it.
It is important that if you change the filament type, the hotend or the nozzle should be well cleaned (cold pull with nylon transparent or similar).
Postato : 17/05/2021 7:44 pm
Utenti
@karl-herbert
I will second that recommendation!
Postato : 17/05/2021 7:46 pm
wes_young
(@wes_young)
@karl-herbert and @cwbullet,
Yep, I have had a lot of success with my MK3S with a variety of materials, but I am a bit nervous with the stock mini after seeing all the issues here. (Recognizing that people without problems don't post as often, so there are tons of well behaved minis out there). So my plan is to test things out and have a V6 ready if I need it.
@karl-herbert, glad to hear things are going well for you, do you have the stock extruder or did you upgrade to something else?
Wes
Postato : 18/05/2021 12:47 pm
@wes_young
I developed the extruder myself according to this functional principle: https://www.bernis-simple-bowden-extruder.com/v2-bernis-magnetic-alu-flexar-extruder/
All components of the extruder are easily accessible, easy maintenance and reliable operation (with integrated filamentsensor).
In the meantime I have converted all couplings to PC-M8x1.25.
wbr,
Karl
Postato : 18/05/2021 6:41 pm
Utenti
@wes_young
I would strongly recommend you follow that path and get good that the stock hotend before altering.  Print all the parts and get some experience and then move to install the V6.
If you have problems, we are here to support you.
Postato : 18/05/2021 6:45 pm
4nthonylin
(@4nthonylin)
@karl-herbert
That extruder looks amazing! Would you mind sharing the STLs and parts list? Would love to build one for myself.
Postato : 18/05/2021 7:28 pm
I agree with @cwbullet and would first do everything possible to get the original components running. The Flexar Magnet extruder is complex to build and requires a lot of precision.
wbr,
Karl
Postato : 18/05/2021 9:17 pm
Crawlerin
(@crawlerin)
With the arrival of extruders in feather-weight category based around planetary gears and small pancakes - like Orbiter, Galileo, Sherpa Mini, ... - do you think MINI would handle a direct drive one day? Some of the recent contestants in SpeedBoatRace challenge feature interesting lightweight designs of direct drives, to lower mass of print head moving at crazy speeds and accelerations. How much does standard assembled MINI hotend even weight? 🙂
There are some interesting things on Bowden extruder side of things, to be fair.
Postato : 18/05/2021 9:52 pm
kevman
(@kevman)
mosquioto users...
Mosquito hot end users, is the cold pull methodology the same as standard on the Mini ? also is there a nozzle change procedure documented for a mosquito, I feel like it should ne simple , but of course I don't want to assume...
Postato : 19/09/2021 2:37 pm
Utenti
RE: Cold pull
The cold pull technique is essentially the same.
Postato : 19/09/2021 2:47 pm
Chicago Keri
(@chicago-keri)
RE: Mosquito cold pull and nozzle change
Been using the Mosquito on a MK2.5s for quite some time now… the cold pull as well as general operation is the same as E3D V6.  The great difference is the fast and easy nozzle change, hot or cold. The procedure is simple… unscrew the old nozzle and screw in the new one to 1.8Nm. That’s it, all done, takes a few seconds.  It can be used with a standard 40w heater or Slice’s 50w heater , which need a larger fuse than the standard 5A for 12v systems.  One could probably increase the speed / flow rate dramatically, but it works great at standard settings.
¡no entiendo Español!
Nein! Nicht Versteh!
Я немного говорю по-русски но не очень хорошо, и...
I'm not very good at English either! Maybe someday I'll find a language I'm good at?
Postato : 20/09/2021 3:10 pm
noseeam
(@noseeam)
sorry if this has been asked before I'm lost there is so many remix and original posts for prusa mini+ Mosquito Magnum Hotend, can someone help me figure out witch is the best one out there please? I have printed the one from Woraphot but don't like how the boden screw fits also cooling issue and the nozzle is too low when adjusting my Z I am already at 1.995
Postato : 24/01/2022 5:57 am
Pagina 15 / 16
