Anyone have a Simplify 3d profile yet for Prusa Mini?
Stránka 1 / 3
Greg's Maker Corner
(@gregs-maker-corner)
I am much more familiar with Simplify 3d and use it for all my other machines. I tried duplicating the settings from Prusa Slicer to S3D but I must have missed something because it wasn't printing quite right. Thought I'd check here and see if anyone has one they can share.
Napsal : 16/12/2019 2:25 pm
Rat_Patrol
(@rat_patrol)
RE: Anyone have a Simplify 3d profile yet for Prusa Mini?
Same issues here. Tried even copying scripts from prusa slicer, the mini didn't like that!
Napsal : 09/01/2020 5:46 am
Don't have a mini, but a lot of the "magic" in S3D is hidden in the gcode. Slice a part in PrusaSlicer, open the gcode in a text editor extract any of the startup gcode and particularly the hardware M20x commands and copy it over. The rest of the settings should be printer-independent.
Napsal : 09/01/2020 6:45 am
Crawlerin
(@crawlerin)
Shouldn't company making S3D take care of putting profiles in? It is paid program and wasn't this one of value propositions, that it has many profiles for various printers that you can download?
Napsal : 09/01/2020 8:23 am
2 lidem se líbí
Neolker
(@neolker)
The true is that support of Simplify3D really sucks and unfortunately keep promises... 😏
Next fail is, that current owners have to buy update to new version as well.
Napsal : 10/01/2020 12:58 am
bolsoncerrado
(@bolsoncerrado)
Posted by: @greg-h3
Same boat here.
No success yet?
Napsal : 11/02/2020 11:50 am
Alex3d
(@alex3d)
@alex-t3 Hi everyone, I copied the gcode from prusaslicer and pasted it into simplify3d but now when the temperature drops to 170 degrees to level the bed start printing at 170 degrees and don't raise the temperature. someone knows why ?
Napsal : 11/03/2020 4:32 pm
Posted by: @alex3d
The placeholder variables are different between PrusaSlicer and Simplify 3D. You can't just copy startup gcode over verbatim. In particular, you need to replace the PrusaSlicer placeholders for bed temperature and nozzle temperature with their S3D equivalents. I've listed the S3D versions on this page(incomplete notes). If you'd care to upload or paste what gcode you're attempting to use here, we can take a look at it and possibly make further suggestions.
Napsal : 11/03/2020 8:41 pm
1 lidem se líbí
Alex3d
(@alex3d)
@bobstr
Thank you very much for answering, the joy I have copied is this:
I've changed the temperature because if it doesn't start printing at bed levels.
I also had to check the box ( relative extrusion distances) if it didn't give problems with the speed.
M83 ; extruder relative mode
M104 S243 ; set extruder temp for bed leveling
M140 S[first_layer_bed_temperature] ; set bed temp
M109 R243; wait for bed leveling temp
M190 S[first_layer_bed_temperature] ; wait for bed temp
G28 ; home all without mesh bed level
G29 ; mesh bed leveling
M104 S[first_layer_temperature] ; set extruder temp
G92 E0.0
G1 Y-2.0 X179 F2400
G1 Z3 F720
M109 S[first_layer_temperature] ; wait for extruder temp
; intro line
G1 X170 F1000
G1 Z0.2 F720
G1 X110.0 E8.0 F900
G1 X40.0 E10.0 F700
G92 E0.0
M221 S100 ; set flow
Napsal : 12/03/2020 4:39 pm
Greg's Maker Corner
@alex3d
Hi, if you go to the Facebook "Prusa 3d Printer Owners" group you can download the .fff file (from Files section) that I created that has the Simplify 3d profile. I would post here but there are no attachments allowed.
https://www.facebook.com/groups/PrusaOfficial/permalink/2613260848729764/
Here is some gcode with S3d variables that may help you.
M140 S[bed0_temperature] ; set bed temp
M109 R170 ; wait for bed leveling temp
M190 S[bed0_temperature] ; wait for bed temp
M104 S[extruder0_temperature] ; set extruder temp
M109 S[extruder0_temperature] ; wait for extruder temp
Napsal : 12/03/2020 5:05 pm
1 lidem se líbí
Hi Greg,
attachments are welcome here, but there is a limit to the various formats.
.fff is not an accepted format,
however if you zip the file, then .zip is an accepted format.
Napsal : 12/03/2020 5:11 pm
1 lidem se líbí
Greg's Maker Corner
@joantabb
Ok, thanks! I didn't try a zip file before. I went ahead and zipped up the Prusa Mini S3d profile that I am using. It's not perfect, but it works well for me. Hopefully others find it useful.
Attachment removed
Napsal : 12/03/2020 5:14 pm
3 lidem se líbí
bolsoncerrado
(@bolsoncerrado)
Hey Greg!
Thanks for that, certainly it will be a good start to play with 🙂
Napsal : 12/03/2020 6:45 pm
1 lidem se líbí
Rat_Patrol
(@rat_patrol)
The profile is a great start, I used your settings and ran a near perfect PLA print.
Thanks!
Napsal : 07/04/2020 9:13 pm
1 lidem se líbí
bolsoncerrado
(@bolsoncerrado)
Same here! Great profile!
Napsal : 08/04/2020 9:31 am
1 lidem se líbí
SS220
(@ss220)
@greg-h3
Thanks for this! Noob question, but I'm curious about the following line in the start script:
M92 E317 ; set steps/unit for extruder
Would this override the new estep value in the new 4.05 version of the firmware?
Napsal : 09/04/2020 4:53 am
1 lidem se líbí
Greg's Maker Corner
@rat_patrol
Glad it is working for you! If you come up with any improvements, please let me know. I have been using it for a while and haven't run into anything significant. I have changed extrusion multiplier, layer heights, temps, etc. - just the usual stuff for different filaments and prints.
Napsal : 11/04/2020 8:13 pm
Greg's Maker Corner
@stevensmith
Yes, the gcode in the startup script would override any steps in the firmware.  So you may want to comment that line out or remove it all together. Same goes for all the other settings in there for acceleration. I left them in there because thats how it was set up in the Prusa Slicer profile- but honestly I'm not sure they need to be there if you'd rather default to the firmware settings.
Napsal : 11/04/2020 8:14 pm
chrispyfur
(@chrispyfur)
Posted by: @greg-h3
I had this question and was provided the following files from Simplify 3D Support.
PrusaResearch_OriginalPrusaMINI_PLA (1)
Napsal : 30/07/2020 1:55 pm
PGe-10
(@pge-10)
I found this yesterday and it's the public release
How To:
https://help.prusa3d.com/en/guide/how-to-import-profiles-to-simplify3d-4-x-windows-macos_18360?fbclid=IwAR0NYX85FFXWJMJUxvE4p5Pu1g27HKoO_mO1s1ZN4DtApbNY09r6amMBHTQ
Download:
https://prusa3d.com/downloads/Cura_S3D/S3D_OriginalPrusa_Profiles.zip
Napsal : 01/08/2020 8:42 am
Stránka 1 / 3
