					                		Prusa MK4 &amp; Octoprint - User mods - OctoPrint, enclosures, nozzles, ...                                    </title>
                <link>https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/</link>
                <lastBuildDate>Mon, 11 May 2026 05:31:03 +0000</lastBuildDate>
                        <title>RE: Prusa MK4 &amp; Octoprint</title>
                        <link>https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-731017</link>
                        <pubDate>Sun, 29 Dec 2024 14:10:26 +0000</pubDate>
                        <description><![CDATA[HiYes It was  a USB cable  problem Thanks for help Doron]]></description>
                        <content:encoded><![CDATA[<p>Hi</p><p>Yes It was  a USB cable  problem </p><p>Thanks for help Doron</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/">User mods - OctoPrint, enclosures, nozzles, ...</category>                        <dc:creator>sonra</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-731017</guid>
                        <link>https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-730845</link>
                        <pubDate>Fri, 27 Dec 2024 02:32:18 +0000</pubDate>
                        <description><![CDATA[Thanks for helpwill try other cable]]></description>
                        <content:encoded><![CDATA[<p>Thanks for help</p><p>will try other cable</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-730845</guid>
                        <link>https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-730837</link>
                        <pubDate>Fri, 27 Dec 2024 00:31:14 +0000</pubDate>
                        <description><![CDATA[My installation is  Octoprint 1.10.3  Python 3.11.2  Octopi 1.1.0  on Pi5Printer is MK4 upgraded to MK4S, firmware 6.1.3.Unless you&#039;re running something else on the Pi that might reset ports...]]></description>
                        <content:encoded><![CDATA[<p>My installation is<br />  Octoprint 1.10.3<br />  Python 3.11.2<br />  Octopi 1.1.0  on Pi5</p><p>Printer is MK4 upgraded to MK4S, firmware 6.1.3.</p><p>Unless you're running something else on the Pi that might reset ports, my best guess is poor cable or connection.</p><blockquote data-userid="257218" data-postid="730834" data-mention="sonra"><div class="wpforo-post-quote-author"><strong>Posted by: @sonra </strong></div><p>Hi</p><p>Thanks for replay</p><blockquote><p> </p></blockquote><p>No i do connect the DOK to the display port (as you only when update OS of  the printer</p><p>1)Can you  check what ver of OctoPrint you use?</p><p>2)   Can you try to  print  large file on your MK4 ?(may be printer model   problem ) </p><p>3)  if you try on your MK4 and it work can you check what software framework is installed on the MK4printer </p><p>I don' t know if  you read me original  topic in the forum but the problem happens  after few hours of printing with no problem</p><p>and i can print small /medium size files</p><p>Hope no big problem for you  </p><p>Regards  Doron</p><p> </p><p> </p><p> </p><p> </p><p> </p><p>0</p><p>3) </p></blockquote><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/">User mods - OctoPrint, enclosures, nozzles, ...</category>                        <dc:creator>ScottW</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-730837</guid>
                        <link>https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-730836</link>
                        <pubDate>Fri, 27 Dec 2024 00:23:19 +0000</pubDate>
                        <description><![CDATA[Can you also check the &quot;resend ratio&quot; (Resendverhältnis in my screenshot) on your printer when it is printing, this value should be 0 or very close to 0. Did you try to use another USB-C cab...]]></description>
                        <content:encoded><![CDATA[<p>Can you also check the "resend ratio" (Resendverhältnis in my screenshot) on your printer when it is printing, this value should be 0 or very close to 0. Did you try to use another USB-C cable between the Pi and the printer? One with good shielding?</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/12/23232068-bildschirmfoto-vom-2024-12-27-01-20-05.png"><img class="alignnone size-medium wp-image-172808" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/12/23232068-bildschirmfoto-vom-2024-12-27-01-20-05-600x217.png" alt="" width="600" height="217" /></a></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/">User mods - OctoPrint, enclosures, nozzles, ...</category>                        <dc:creator>Walter Layher</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-730836</guid>
                        <link>https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-730835</link>
                        <pubDate>Fri, 27 Dec 2024 00:19:08 +0000</pubDate>
                        <description><![CDATA[This is the software string from the bottom of the OctoPrint screen: OctoPrint 1.10.3Python 3.9.2OctoPi* 1.0.0cam (build 2024.06.18.101629)My MK4 is running on firmware version 6.1.3.My prin...]]></description>
                        <content:encoded><![CDATA[<p>This is the software string from the bottom of the OctoPrint screen: OctoPrint 1.10.3Python 3.9.2OctoPi* 1.0.0cam (build 2024.06.18.101629)<br />My MK4 is running on firmware version 6.1.3.</p><p>My printer is currently printing, so I cannot start another print right now. But I have checked what the biggest files were I printed on it since the last upgrade of the OctoPi image. All ran without a problem:</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/12/a1a50bab-bildschirmfoto-vom-2024-12-27-01-16-13.png"><img class="alignnone size-medium wp-image-172807" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/12/a1a50bab-bildschirmfoto-vom-2024-12-27-01-16-13-600x500.png" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-730835</guid>
                        <link>https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-730834</link>
                        <pubDate>Fri, 27 Dec 2024 00:08:45 +0000</pubDate>
                        <description><![CDATA[HiThanks for replay No i do connect the DOK to the display port (as you only when update OS of  the printer1)Can you  check what ver of OctoPrint you use?2)   Can you try to  print  large fi...]]></description>
                        <content:encoded><![CDATA[<p>Hi</p><p>Thanks for replay</p><blockquote><p> </p></blockquote><p>No i do connect the DOK to the display port (as you only when update OS of  the printer</p><p>1)Can you  check what ver of OctoPrint you use?</p><p>2)   Can you try to  print  large file on your MK4 ?(may be printer model   problem ) </p><p>3)  if you try on your MK4 and it work can you check what software framework is installed on the MK4printer </p><p>I don' t know if  you read me original  topic in the forum but the problem happens  after few hours of printing with no problem</p><p>and i can print small /medium size files</p><p>Hope no big problem for you  </p><p>Regards  Doron</p><p> </p><p> </p><p> </p><p> </p><p> </p><p>0</p><p>3) </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-730834</guid>
                        <link>https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-730827</link>
                        <pubDate>Thu, 26 Dec 2024 22:53:43 +0000</pubDate>
                        <description><![CDATA[Do you by any chance have the USB thumb drive inserted in your MK4? It is just a suspicion of mine, but the USB port on the display and the USB port on the buddy port that is used to connect...]]></description>
                        <content:encoded><![CDATA[<p>Do you by any chance have the USB thumb drive inserted in your MK4? It is just a suspicion of mine, but the USB port on the display and the USB port on the buddy port that is used to connect to OctoPrint perhaps conflict with each other. I only connect my USB drive to the MK4 for firmware updates and have it not inserted when I print with OctoPrint. The drive is not needed at all when printing via OctoPrint. I vaguely remember seeing that error some time in the early days with my MK4, but I am not sure if it was that same error.</p><p>I would suggest removing the USB drive from the MK4 and give it another try if it works that way for you.</p><p>About the file size I use with OctoPrint, see screenshot from today. I also have a similarly sized print currently running on my MK3S+ and I have printed files sized over 90 MB in the past with no problem.</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/12/e20d0b81-bildschirmfoto-vom-2024-12-26-23-43-07.png"><img class="alignnone size-medium wp-image-172806" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2024/12/e20d0b81-bildschirmfoto-vom-2024-12-26-23-43-07-600x500.png" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-730827</guid>
                        <link>https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-730826</link>
                        <pubDate>Thu, 26 Dec 2024 22:48:35 +0000</pubDate>
                        <description><![CDATA[Sames...-rw-r--r-- 1 octoprint-mk4 octoprint-mk4 67M May 26  2024 &#039;SStopfmitloechern v5_0.4n_0.2mm_PETG_MK4ISMMU3_13h30m.gcode&#039;Largest file I&#039;ve successfully printed (that&#039;s still lying arou...]]></description>
                        <content:encoded><![CDATA[<p>Sames...</p><pre contenteditable="false">-rw-r--r-- 1 octoprint-mk4 octoprint-mk4 67M May 26  2024 'SStopfmitloechern v5_0.4n_0.2mm_PETG_MK4ISMMU3_13h30m.gcode'</pre><p>Largest file I've successfully printed (that's still lying around on the Octoprint instance) -- Its a flower pot.</p><p>(Dedicated PI4, USB attached SSD, LACK enclosure, but its generally left slightly open for heat reasons - The PI/SSD are both external to the MK4).</p><p>In the middle of a 6 hour print (but its only 12Mb of gcode).</p><p>I'd agree w/ Scott, and lean toward your PI environment, and/or cable... </p><p> </p><p> </p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/">User mods - OctoPrint, enclosures, nozzles, ...</category>                        <dc:creator>David Holland</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-730826</guid>
                        <link>https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-730825</link>
                        <pubDate>Thu, 26 Dec 2024 22:07:35 +0000</pubDate>
                        <description><![CDATA[Posted by: @sonra 
Hi
Did any one of you try to print big file ( &gt;20Mbyte) using the OctoPrint and it work ?
all my tries was stop after few hour with  serial exception error  you can ...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="257218" data-postid="730824" data-mention="sonra">
<p>Hi</p>
<p>Did any one of you try to print big file ( &gt;20Mbyte) using the OctoPrint and it work ?</p>
<p>all my tries was stop after few hour with  serial exception error  you can see the  full story in  a post that  i wrote and did not get any</p>
<p>response from this forum or the OP forum</p>
<p>MK4  Framework   6.1.3</p>
<p>I doubt I have printed a gcode file that large with Octoprint, but file size should not matter -- commands are sent to the printer one-by-one.  I have certainly printed 12+ hours-long prints, whereas the last failure was at 3hours 15 minutes. That's a relatively short time, and I routinely have prints longer that that which complete without any issues.</p>
<p>I found your logs on the Octoprint forum and reviewed them.  From the logs, the issue does not look like an Octoprint problem or Rpi power problem.  The error you are getting indicates a communication loss (i.e., either the printer stopped responding to Octoprint, or communication between the two was lost). </p>
<p>It *could* be a Prusa firmware fault, but I have not experienced this or seen anyone else report it.  What was the state of the MK4 screen after this happened?  Did it still show "serial printing"?  Was it responsive?  Was it still heating the bed and toolhead?  There have been (rare) overheating problems with the buddy board; particularly with long prints in an enclosure, a few folks have had it "red-screen" and spontaneously reboot.  </p>
<p>It *could* be a bad cable, poorly shielded cable, or loose cable connection. An easy test would be to replace the cable and try again.  </p>
<p>It *could* be some other process on the Pi interfering with comms.  Do you have anything other than Octoprint running on the Pi?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-730825</guid>
                        <link>https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-730824</link>
                        <pubDate>Thu, 26 Dec 2024 21:41:07 +0000</pubDate>
                        <description><![CDATA[HiDid any one of you try to print big file ( &gt;20Mbyte) using the OctoPrint and it work ?all my tries was stop after few hour with  serial exception error  you can see the  full story in  ...]]></description>
                        <content:encoded><![CDATA[<p>Hi</p><p>Did any one of you try to print big file ( &gt;20Mbyte) using the OctoPrint and it work ?</p><p>all my tries was stop after few hour with  serial exception error  you can see the  full story in  a post that  i wrote and did not get any</p><p>response from this forum or the OP forum</p><p>MK4  Framework   6.1.3</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-mods-enclosures-nozzles/prusa-mk4-octoprint/paged/18/#post-730824</guid>
