					                		Stacking LACK IKEA Table Enclosures.. - Community mods                                    </title>
                <link>https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/</link>
                <lastBuildDate>Tue, 10 Mar 2026 08:56:54 +0000</lastBuildDate>
                        <title>RE: Stacking LACK IKEA Table Enclosures..</title>
                        <link>https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-759736</link>
                        <pubDate>Sat, 02 Aug 2025 13:04:11 +0000</pubDate>
                        <description><![CDATA[Posted by: @mixer3d Great, but seems that in the max Z position there is not enough space for ptfe tube, so it will bend and create more friction, still it&#039;s not the issue for smaller object...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="538936" data-postid="759735" data-mention="mixer3d"><div class="wpforo-post-quote-author"><strong> Posted by: @mixer3d </strong></div><p>Great, but seems that in the max Z position there is not enough space for ptfe tube, so it will bend and create more friction, still it's not the issue for smaller objects. But personally since i print also taller objects i used extensions for the table legs to have enough space even with max size in Z axis. </p></blockquote><p>This is a very good point! Apologies, I should have mentioned before that I only printed small objects (maximum height 15cm) with my Prusa Mini's so this was never an obstacle for me, but those wanting this kind of set up to print tall objects should definitely be mindful of the height limitations.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/user-and-hardware-mods/">Community mods</category>                        <dc:creator>Jake</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-759736</guid>
                        <link>https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-759735</link>
                        <pubDate>Sat, 02 Aug 2025 12:59:27 +0000</pubDate>
                        <description><![CDATA[Great, but seems that in the max Z position there is not enough space for ptfe tube, so it will bend and create more friction, still it&#039;s not the issue for smaller objects. But personally si...]]></description>
                        <content:encoded><![CDATA[<p>Great, but seems that in the max Z position there is not enough space for ptfe tube, so it will bend and create more friction, still it's not the issue for smaller objects. But personally since i print also taller objects i used extensions for the table legs to have enough space even with max size in Z axis. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/user-and-hardware-mods/">Community mods</category>                        <dc:creator>mixer3d</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-759735</guid>
                        <link>https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-759710</link>
                        <pubDate>Sat, 02 Aug 2025 07:25:26 +0000</pubDate>
                        <description><![CDATA[Thanks so much! I highly recommend looking into this type of enclosure if it interests you - it was pretty cheap to put together and worked surprisingly well. I had the perspex custom ordere...]]></description>
                        <content:encoded><![CDATA[<p>Thanks so much! I highly recommend looking into this type of enclosure if it interests you - it was pretty cheap to put together and worked surprisingly well. I had the perspex custom ordered and cut so that was probably the most costly part but in total it probably cost around £60 including the tables which people seem to pretty much give away for free on Facebook Marketplace.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-759710</guid>
                        <link>https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-759708</link>
                        <pubDate>Sat, 02 Aug 2025 07:11:28 +0000</pubDate>
                        <description><![CDATA[It looks so compact and clean 😀 I&#039;ve got single printer with original enclosure for a Mini and it&#039;s quite messy because you can see every bit of snipped filament inside of it. Also because i...]]></description>
                        <content:encoded><![CDATA[<p>It looks so compact and clean 😀 </p><p>I've got single printer with original enclosure for a Mini and it's quite messy because you can see every bit of snipped filament inside of it. Also because it is black it needs a bit more light to make it bright - your white Lack tables look so much better :)</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/user-and-hardware-mods/">Community mods</category>                        <dc:creator>_KaszpiR_</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-759708</guid>
                        <link>https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-759681</link>
                        <pubDate>Fri, 01 Aug 2025 21:32:10 +0000</pubDate>
                        <description><![CDATA[Posted by: @_kaszpir_ Could you show some pictures with details of the assembly, printer placement/slabs, hole placement for filament or cables etc?Sure thing! I can&#039;t take credit for the bu...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="523281" data-postid="759658" data-mention="_kaszpir_"><div class="wpforo-post-quote-author"><strong> Posted by: @_kaszpir_ </strong></div><p>Could you show some pictures with details of the assembly, printer placement/slabs, hole placement for filament or cables etc?</p></blockquote><p>Sure thing! I can't take credit for the build, and you're probably more likely to get the answers you're looking for from <a href="https://blog.prusa3d.com/cheap-simple-3d-printer-enclosure_7785/" target="_blank" rel="noopener">this page</a>.</p><p><a href="https://www.youtube.com/watch?v=laTXCyLQIYs&amp;ab_channel=ChrisRiley" target="_blank" rel="noopener">This</a> is also a fantastic video tutorial which shows the full assembly.</p><p>Nonetheless I'll share the few photos that I've got and some relevant points. The enclosure and printers are currently for sale and semi-packed up as I've scaled up production and therefore had to upgrade to some better printers. </p><p>• Printers and slabs were placed central in the enclosure. One concrete slab per enclosure seemed to the trick and they are around 16mm thick. I also spray painted them to seal any dust.</p><p>• I cut a small inlet into the LACK tables at the back for cables to pass through. Doesn't look the most aesthetic but it does the job and it's out of sight.</p><p>• For filament, I opted <a href="https://www.printables.com/model/85376-prusa-minimini-squash-ball-feet-system-spool-holde" target="_blank" rel="noopener">this</a> mod for Prusa Mini's which allows you to save space within each individual enclosure by mounting the filament spool onto the printer and forgoing the standard Prusa Mini filament mount/stand. There are many iterations of this, as well as alternative solutions, including some which feed filament into the enclosure through PTFE tubes but this was too much hassle for me and I didn't want to have to worry about a keep-dry solution for filament outside of the enclosure.</p><p> </p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/08/187c066e-download-1.png"><img class="alignnone size-medium wp-image-179139" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/08/187c066e-download-1-600x500.png" alt="" width="600" height="500" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/08/b910cd69-download.png"><img class="alignnone size-medium wp-image-179138" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/08/b910cd69-download-600x500.png" alt="" width="600" height="500" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/08/4568a474-download-2.png"><img class="alignnone size-medium wp-image-179137" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/08/4568a474-download-2-600x500.png" alt="" width="600" height="500" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/08/2c65d623-playlist.mkv">playlist</a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-759681</guid>
                        <link>https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-759658</link>
                        <pubDate>Fri, 01 Aug 2025 19:50:48 +0000</pubDate>
                        <description><![CDATA[Could you show some pictures with details of the assembly, printer placement/slabs, hole placement for filament or cables etc?]]></description>
                        <content:encoded><![CDATA[<p>Could you show some pictures with details of the assembly, printer placement/slabs, hole placement for filament or cables etc?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-759658</guid>
                        <link>https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-759609</link>
                        <pubDate>Fri, 01 Aug 2025 14:32:01 +0000</pubDate>
                        <description><![CDATA[Sorry to resurrect but I just wanted to post an update that three enclosures stacked produced very little vibration / side-to-side movement.. or at least, not enough to affect print quality ...]]></description>
                        <content:encoded><![CDATA[Sorry to resurrect but I just wanted to post an update that three enclosures stacked produced very little vibration / side-to-side movement.. or at least, not enough to affect print quality when all three printers are running.
Very much recommend a setup like this.. it was a godsend when I was starting out and had a lot of printing needs but not much space for printers.]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-759609</guid>
                        <link>https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-694746</link>
                        <pubDate>Tue, 16 Jan 2024 23:17:03 +0000</pubDate>
                        <description><![CDATA[hm sorry for confusion,  I meant BonkersBenchy in my posts, not SwoleBenchy...]]></description>
                        <content:encoded><![CDATA[<p>hm sorry for confusion,  I meant <strong>BonkersBenchy</strong> in my posts, not SwoleBenchy...</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-694746</guid>
                        <link>https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-694720</link>
                        <pubDate>Tue, 16 Jan 2024 20:08:45 +0000</pubDate>
                        <description><![CDATA[ah, and i realized that probably we are talking about two different flies, i don&#039;t know the &#039;SwoleBenchy&#039; but the file i&#039;m reffering to is &#039;BonkersBenchy&#039; and was released together with 5.1....]]></description>
                        <content:encoded><![CDATA[<p>ah, and i realized that probably we are talking about two different flies, i don't know the 'SwoleBenchy' but the file i'm reffering to is 'BonkersBenchy' and was released together with 5.1.0-alpha1 firmware for MINI, and you have to use IS to print it:</p><p>https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v5.1.0-alpha1</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-694720</guid>
                        <link>https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-694625</link>
                        <pubDate>Tue, 16 Jan 2024 09:10:37 +0000</pubDate>
                        <description><![CDATA[maybe to be on the safe side just run the provided gcode on PLA ready printer? at least you will understand what this bonxersbenchy is ;)  still it&#039;s printer acceleration and vibrations of t...]]></description>
                        <content:encoded><![CDATA[<p>maybe to be on the safe side just run the provided gcode on PLA ready printer? at least you will understand what this bonxersbenchy is ;)  still it's printer acceleration and vibrations of the table, PETG is different than PLA</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/user-and-hardware-mods/stacking-lack-ikea-table-enclosures/#post-694625</guid>
