Idiot-Proofing the Door Hinges
So, I'm the idiot!
After reading the waning closely and seeing that if you screw up assembling the door hinges, there is no way to take them apart, I still screwed it up! Now I have to print four more Enclosure Hinges and four more Door Hinges, but it only came with four extra hinge pins, and I need eight! After a close inspection of the door hinge, I see that it is a very nice aesthetic design, but my problems would be solved if there were two small holes at the ends of the hinge pins so I could push the pins out using the smallest provided Allen wrench. With a Dremel and some butchering, I made the required modifications!
I feel like this could be part of the original design without compromising the form and function of the part.
Veröffentlicht : 12/09/2023 4:32 pm
