Filament guide for Mini Enclosure
domble
(@domble)
Got a Mk4 at work.  And a Mini at home.  Mini enclosure misses out on the Mk4 enclosure's filament guide.   When printing, I found the sensor and PTFE tube tended to pull all the way up to the spool and risk jamming against the coils of filament.
So I did a quick and dirty hack of the Mk4 guide to fit the mini -
Chopped up the Mk4 guide (in F360) and re-assembled (I did miss one countersink, had to drill it).
Worked!  With a slightly longer tube into the filament sensor.
Although the tube does pull out of the filament sensor easily while loading filament.   Might need glue...
But thinking; just needs a re-modelled filament sensor, bolted solidly to the front frame, and that'd be neater and just as effective.  Just need time to do it...
dom.
Este debate ha sido modificado el hace 1 year por domble
Respondido : 13/07/2024 9:40 am
