Enclosure heating - What do you use?
Eule
 Eule
(@eule)
Dear all,
I have my MK3S+ in a IKEA lack enclosure in the basement and now, as winter is coming, the temperature drops below 10°C. Currently I carefully use a heat gun to avoid the minitemp error.
I am now searching for a good way to add a heating to the enclosure. So I would like to ask you about the solutions which works good for you.
Greetings
Oliver
Opublikowany : 22/11/2024 8:01 pm
KPS
 KPS
(@kps)
XMAS String of C9 Incandescent Bulbs RE: Enclosure heating - What do you use?
Wanted something easy, available and relatively safe... went with string of approx. 20 incandescent outdoor C9 Xmas lights. We have a large enclosed area (4 x 3 x 3 feet) and each string deployed in the enclosure raises the enclosed air temp by 4-5C even with a small exhaust fan running. Heat is disbursed, little if any draft. You can spread the lights around &/or leave them in the plastic cradle that they usually arrive in from the OEM. Bottom line is that if ambient temp is 5C, we have an enclosure temp of 10+C with one string and 15+C if also lightning the second string. Printing with an XL in the enclosure adds about another 5C. We have a round thermometer on a side wall of the enclosure and monitor it and the printer with a security cam. Not very sophisticated but it works.
Opublikowany : 22/11/2024 10:11 pm
Brian
(@brian-12)
How about the heat bed.  That's what I've always used.  Just turn it on prior to the print until the enclosure has reached your desired temperature.
Opublikowany : 22/11/2024 10:23 pm
_KaszpiR_
(@_kaszpir_)
Get a smart power socket controllable over the WiFi and add a hair dryer inside 🙂
Hair dryers have a limited heat output to avoid burning hair, yet they have enough flow to heat up the chamber pretty quick.
With additional temperature sensor you can trigger heating and keep the temperature on desired level automatically.
Opublikowany : 22/11/2024 11:34 pm
jsw
 jsw
(@jsw)
Just the heat from the printer.
I did add a thermally-controlled (somewhat) fan to the enclosure, but I've found that it makes zero difference in print quality as long as the temperature inside the box is steady and draft-free.
Opublikowany : 23/11/2024 12:55 am
1 ludzie polubili
Eule
 Eule
(@eule)
I just found that I cannot use the heat from the printer, as if there is the Minitemp error you cannot start the bed heating...
Opublikowany : 01/12/2024 4:07 pm
Gavin
(@gavin-8)
An electric seedling germinating heater works. I stick one in the chamber to get things started in winter. I'm currently trying to get some ASA to work and about to give it a go running heat through the print.
Opublikowany : 19/11/2025 8:01 pm
2 ludzie polubili
Sembazuru
(@sembazuru)
Posted by: @gavin-8
Gotta love the ingenuity of off-label problem solving. 👍
See my (limited) designs on:
Opublikowany : 19/12/2025 8:26 pm
mnentwig
(@mnentwig)
Software error fixed in hardware ... never seen that happen before. No, really.
Opublikowany : 19/12/2025 11:50 pm
