Z offset issues
I switched from cura to prusaslicer and ran into strange issues with z offset. I have matched the machine config, pre-code, and post-code in both slicers. The print that is sliced by cura works perfectly fine, but that from prusaslicer has a gap (>0.5mm) at first layer and simply causes print to fail.
I attached a screen shot of both g-code (a simple 1cm x 1cm slab with only two layers as height). Could anyone help me look at this? (Please let me know if you need any additional information)
Printer: Qidi imate s
Cura version: 4.8
Prusaslicer version: 2.4.0
Thanks in advance for your help!
This topic was modified 4 years ago by Rongtao Ma
Posted : 12/10/2022 4:22 am
