Your experience with 2.3.0-alpha1 and where to download?
prusanewuser
(@prusanewuser)
Hi, is this version working fine? When will the final release version be available? I want to try out the ironing feature.
Where can I download 2.3.0-alpha1? Can't find it on https://www.prusa3d.com/drivers/
Best Answer by karl-herbert:
Posted by: @peter-c20
You can download it here (meanwhile alpha3): https://github.com/prusa3d/PrusaSlicer/releases
Respondido : 09/11/2020 9:06 pm
RE: Your experience with 2.3.0-alpha1 and where to download?
Respondido : 09/11/2020 9:34 pm
1 les gusta
prusanewuser
(@prusanewuser)
I tired to print from 2.3.0-alpha3 via Octoprint but such option seems to be disabled. Is it moved to somewhere else?
Respondido : 11/11/2020 8:11 pm
@peter-c20
add a physical printer:
Respondido : 11/11/2020 10:18 pm
prusanewuser
(@prusanewuser)
Thanks. Even after adding the printer, it does not show up under the Printer Settings tab on the top left. Is this the new behavior? On 2.2.0, printer shows up under that tab.
Anyway, I got the same issue mentioned in:
https://www.gitmemory.com/issue/prusa3d/PrusaSlicer/2689/515964552
even I have already installed Bonjour.
https://github.com/prusa3d/PrusaSlicer/issues/1781
Respondido : 12/11/2020 2:48 pm
Gordon W
(@gordon-w)
@peter-c20
The changes introduced (like physical printers) are described here https://github.com/prusa3d/PrusaSlicer/releases/tag/version_2.3.0-alpha1 If you've added the printer and it's not showing then you've found a bug 😀
Respondido : 12/11/2020 4:29 pm
