					                		Wiping Tower Form - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/wiping-tower-form/</link>
                <lastBuildDate>Thu, 16 Apr 2026 01:28:36 +0000</lastBuildDate>
                        <title>RE: Wiping Tower Form</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/wiping-tower-form/#post-784344</link>
                        <pubDate>Wed, 04 Mar 2026 07:19:16 +0000</pubDate>
                        <description><![CDATA[ah, yes, this is a good idea. thanks for that!]]></description>
                        <content:encoded><![CDATA[<p>ah, yes, this is a good idea. thanks for that!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>HumpaPrinta</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/wiping-tower-form/#post-784344</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/wiping-tower-form/#post-784266</link>
                        <pubDate>Tue, 03 Mar 2026 15:50:24 +0000</pubDate>
                        <description><![CDATA[If you are going for the Tetris / Jenga block bit for the purge / wipe tower... What you could do is find the models of the shape you want, then right click on the object and then select wip...]]></description>
                        <content:encoded><![CDATA[<p>If you are going for the Tetris / Jenga block bit for the purge / wipe tower... What you could do is find the models of the shape you want, then right click on the object and then select wipe options and you can select both wipe into object and wipe into this objects infill, you would still have the tower to keep the height and depending on the volume of purge and the height, it would still need the regular tower. <br /><br /><img class="aligncenter size-full wp-image-184847" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/03/3884a53a-2026-03-03_16h46_05.png" alt="" width="1535" height="561" /><br /><br /><br /></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>Same Old Shane</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/wiping-tower-form/#post-784266</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/wiping-tower-form/#post-784259</link>
                        <pubDate>Tue, 03 Mar 2026 14:38:44 +0000</pubDate>
                        <description><![CDATA[This is something, but for me not &quot;best practice&quot; as it will impact the default cleaning path. 20mm might be enough, even 15mm but i&#039;d prefer a proper solution where when you reduce from 30 ...]]></description>
                        <content:encoded><![CDATA[<p>This is something, but for me not "best practice" as it will impact the default cleaning path. 20mm might be enough, even 15mm but i'd prefer a proper solution where when you reduce from 30 to 20, some other value would rise to keep the path. or as suggested, an L shape with "snap to border" feature.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/wiping-tower-form/#post-784259</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/wiping-tower-form/#post-784243</link>
                        <pubDate>Tue, 03 Mar 2026 11:24:50 +0000</pubDate>
                        <description><![CDATA[Joan,Nice find.  Thanks for posting this.  I have had the same question.   Posted by: @joantabb You can change the width of the purge tower, but you need to be in Normal Mode or Expert Mode ...]]></description>
                        <content:encoded><![CDATA[<p>Joan,</p><p>Nice find.  Thanks for posting this.  I have had the same question.  </p><blockquote data-userid="951" data-postid="784238" data-mention="joantabb"><div class="wpforo-post-quote-author"><strong> Posted by: @joantabb </strong></div><p>You can change the width of the purge tower, but you need to be in Normal Mode or Expert Mode to view the options <br /><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/03/b5c61b18-wipe-tower.png"><img class="alignnone size-medium wp-image-184845" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/03/b5c61b18-wipe-tower-600x500.png" alt="" width="600" height="500" /></a><br />In the example above, I have reduced the width to 30mm <br />regards Joan</p></blockquote><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>cwbullet</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/wiping-tower-form/#post-784243</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/wiping-tower-form/#post-784238</link>
                        <pubDate>Tue, 03 Mar 2026 11:07:28 +0000</pubDate>
                        <description><![CDATA[You can change the width of the purge tower, but you need to be in Normal Mode or Expert Mode to view the options In the example above, I have reduced the width to 30mm regards Joan]]></description>
                        <content:encoded><![CDATA[<p>You can change the width of the purge tower, but you need to be in Normal Mode or Expert Mode to view the options <br /><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/03/b5c61b18-wipe-tower.png"><img class="alignnone size-medium wp-image-184845" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/03/b5c61b18-wipe-tower-600x500.png" alt="" width="600" height="500" /></a><br />In the example above, I have reduced the width to 30mm <br />regards Joan</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/wiping-tower-form/#post-784238</guid>
                        <title>Wiping Tower Form</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/wiping-tower-form/#post-784226</link>
                        <pubDate>Tue, 03 Mar 2026 09:22:33 +0000</pubDate>
                        <description><![CDATA[Does anyone know if there is a possibility to change the form of the wiping tower?It would be nice to have it rotateable or even in some L shape to win some net printing place]]></description>
                        <content:encoded><![CDATA[<p>Does anyone know if there is a possibility to change the form of the wiping tower?</p><p>It would be nice to have it rotateable or even in some L shape to win some net printing place</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/03/aa6d1bd6-screenshot-2026-03-03-102000.png"><img class="alignnone size-medium wp-image-184842" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/03/aa6d1bd6-screenshot-2026-03-03-102000-600x500.png" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/wiping-tower-form/#post-784226</guid>
