Why my slice is bigger than world size?
Hello,
I'm having an issue with PrusaSlicer where the exported slice is much larger than expected.
I imported an STL file into PrusaSlicer, and there was no prompt asking to confirm or convert the units. The displayed world size in the PrusaSlicer panel is as perferct, with every dimension of less than 7 cm.
However, after exporting the slice (in .zip format), I noticed that each layer of the slice is about three times larger than expected. I randomly checked one of the exported slices as a reference, could you give me some advice about how to correct it?
I’m not a native English speaker, feel free to ask for further clarifications if needed.
Thanks in advance for your help!
Opublikowany : 05/11/2024 5:07 pm
