Where are defined actually print speeds
Julien
(@julien-4)
First of all : Happy New Year !
I'm doing some test with flex filament. I noticed that one brand is be printed much slower than an other one. As I get much better result with the first one, I wanted to try the second one at a lower speed. But when I'm looking at the speed settings in the print settings tab I see that all parameters are the same. So, where are actually set the speed parameters for a given filament type/brand ?
Regards,
Julien
Postato : 01/01/2024 3:55 pm
RE: Where are defined actually print speeds
you didn't say which profiles, so I am guessing...    probably 'Max Volumetric Speed'  in Filament Settings> Advanced.
this parameter controls print speed, relative to volume of filament extruded, the smaller the value, the slower the print speed.
Postato : 01/01/2024 4:15 pm
Julien
(@julien-4)
I read the Max Volumetric Speed documentation. I will try.
Thank you
Postato : 01/01/2024 8:41 pm
