Vertical cut and cut middle out in PrusaSlicer
There is allready horizontal cut.
I would need also the vertical cut and cut what is left and right or top and bottom, to print what is in the middle.
LP, W
Napsal : 31/12/2020 1:05 pm
RE: Vertical cut and cut middle out in PrusaSlicer
If you rotate the part on the X or Y axis first, it is possible to cut vertical (now in horizontal position).
Napsal : 01/01/2021 2:25 am
2 lidem se líbí
Think of a wood shop. They don't have a separate band saw for different cuts. They rotate the part. We may eventually see something more flexible, but you can get most things done as-is.
Napsal : 01/01/2021 6:38 am
