Unrequested insertion of different materiel as support in a multimaterial print on the XL 5T
amundsen
(@amundsen-2)
Hello,
I want to print a PETG object to test some supports. On one side I'm trying to use PLA (tool #2, pink color in second picture ) as support for a curve (this support is actually imported as a part itself). On another side I am trying to use PETG (tool #1, orange color in second picture) as a support on another side of the object. However where the PETG is supposed to be used as support, the upmost layer in the PETG support is sliced as PLA (see pictures).
To me having two materials used within a support sounds like a bug but maybe there is some setting I'm not aware of?
This topic was modified 4 days ago by amundsen
Posted : 07/09/2025 8:19 am
I think its because you have a different extruder defined for support and support interface, ie 1 and 0.  Set the interface value to the same as the main support.
As you didnt attach a project file to examine and adjust then I can't be certain.
Posted : 07/09/2025 10:21 am
