uninstall completely
maseruki
(@maseruki)
Hello, I want to completely delete prussaslicer and all its configurations, it is necessary for me, since I have tried to install another machine and current previous things have been installed, when trying to change the name of one it has been duplicated and I do not know how to restore everything to 0.Can you help me?thank youThis text has been translated with Google, sorry if I say something stupid
Best Answer by _KaszpiR_:
Uninstall PrusaSlicer using system uninstall.
Then move directories to another location or delete it (assuming you use standard Windows installation paths):
C:\Program Files\Prusa3D\PrusaSlicer
C:\Users\<your_username_here>\AppData\Roaming\PrusaSlicer
C:\Users\All Users\AppData\Roaming\PrusaSlicer
Posted : 10/09/2023 9:16 pm
_KaszpiR_
(@_kaszpir_)
RE: uninstall completely
Posted : 11/09/2023 6:23 am
Before you uninstall it you can also use Help>Show Configuration Folder to locate where its storing all the profiles.   You can then remove those once you have uninstalled as they are kept between installs.
Posted : 11/09/2023 7:26 am
maseruki
(@maseruki)
Thank you for your answers. Change the name in AppData\Roaming\PrusaSlicer and install it, then I just had to make a copy of the parameters that interested me.
thank you
Posted : 11/09/2023 6:03 pm
TupacIlmond
(@tupacilmond)
Certainly, to completely uninstall PrusaSlicer, follow these steps:
Use the system uninstall feature.Remove or relocate these directories (standard Windows paths):C:\Program Files\Prusa3D\PrusaSlicerC:\Users<your_username_here>\AppData\Roaming\PrusaSlicerC:\Users\All Users\AppData\Roaming\PrusaSlicer
Posted : 05/11/2023 7:12 am
CasimerSchmidt
(@casimerschmidt)
Posted by: @tupacilmond
Great support. I'll try it.
Posted : 28/11/2023 4:23 am
