Under extrusion after crossing
Hi, when printing supports, I have the beginning underextruded.
When it goes from one part to another and starts printing. I have a direct extruder, retraction 1mm 25mm there and 25mm back.
Disabled retraction when changing layers
I print slowly, PETG 230 degree
Prusa slicer
Thanks guys ..
Veröffentlicht : 24/05/2023 6:00 pm
RE: Under extrusion after crossing
Assuming you have your esteps set correctly, your filament is dry, and you’ve calibrated your flow rate, try going through the process at http://retractioncalibration.com/
I use this for every new filament I try.
Veröffentlicht : 25/05/2023 3:26 am
