Unable to reload:
Träd-E
(@trad-e)
Unable to reload:
Right click "Reload from disk" - This has for some reason never worked for me, I found very little info on this specific issue, only a handful hits on the interwebs.. It's strange because the path it gives me is correct, the file is there, hard drive is working and I can reimport it just fine..
Posted : 17/12/2025 7:12 pm
Mike B
(@mike-b-3)
RE: Unable to reload:
What OS are you running on?  I've only ever encountered this when I renamed the STL file.  I think you checked that based on your comments.  Is there anything different about where you're storing your models, like on a NAS or cloud service that might make it dynamically load instead of being instantly available?  Just throwing out ideas...
Posted : 17/12/2025 10:24 pm
BaconFase
(@baconfase)
  1. Open [projectfile.3mf] in PS
  2. Import an [example.stl] file into PS project. It's a cube.
  3. Open [example.stl] file in F360 to add a hat on top of the cube. Export model as [example.stl]
  4. In PS rightclick on [example.stl], reload from disk.
  5. Cube now has a hat on it.
¯\_(ツ)_/¯
Posted : 18/12/2025 6:15 am
Träd-E
(@trad-e)
Hmm, this has strangely started to work now, I didn't even change anything 😛
Both very nice and annoying at the same time.....
This post was modified 3 months ago by Träd-E
Posted : 29/12/2025 7:44 pm
