					                		Thick bridges and &#039;thin&#039; bridges in the same print? - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/thick-bridges-and-thin-bridges-in-the-same-print/</link>
                <lastBuildDate>Tue, 16 Jun 2026 06:35:23 +0000</lastBuildDate>
                        <title>RE: Thick bridges and &#039;thin&#039; bridges in the same print?</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/thick-bridges-and-thin-bridges-in-the-same-print/#post-744264</link>
                        <pubDate>Sat, 05 Apr 2025 08:07:46 +0000</pubDate>
                        <description><![CDATA[I don&#039;t think it&#039;s possible Gregor.  You can select thick/thin for different Objects but you cant mix them in the same Object.]]></description>
                        <content:encoded><![CDATA[<p>I don't think it's possible Gregor.  You can select thick/thin for different Objects but you cant mix them in the same Object.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/thick-bridges-and-thin-bridges-in-the-same-print/#post-744264</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/thick-bridges-and-thin-bridges-in-the-same-print/#post-744242</link>
                        <pubDate>Sat, 05 Apr 2025 03:57:15 +0000</pubDate>
                        <description><![CDATA[Hi Gregor Buehrer.Your question is a bit confusing. However, I understand that You can try using Modifier Meshes or Variable Layer Height in your slicer.]]></description>
                        <content:encoded><![CDATA[<p>Hi Gregor Buehrer.</p><p>Your question is a bit confusing. However, I understand that You can try using Modifier Meshes or Variable Layer Height in your slicer.</p><p class="" data-start="3801" data-end="3901"> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>LaurineSatterfield</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/thick-bridges-and-thin-bridges-in-the-same-print/#post-744242</guid>
                        <title>Thick bridges and &#039;thin&#039; bridges in the same print?</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/thick-bridges-and-thin-bridges-in-the-same-print/#post-743927</link>
                        <pubDate>Thu, 03 Apr 2025 15:35:32 +0000</pubDate>
                        <description><![CDATA[Hi thereI need help. I am having a file that needs to have the normal bridge on one height and the thick bridge on another one. It prints OK without the thin bridges but I get sink marks. It...]]></description>
                        <content:encoded><![CDATA[<p>Hi there<br />I need help. I am having a file that needs to have the normal bridge on one height and the thick bridge on another one. <br />It prints OK without the thin bridges but I get sink marks. It's a mess with thick bridges all over but no sink marks. That's why the combination would be great.<br />Would be good to have the two different bridge types in the same print file. However, I don't know how to do it. I don't find it as a modifier, I can only choose one bridge type for the file in the general settings. Does anyone knows how to program the thick bridges either by modifier or as a g-code in user defined g-code section?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>Gregor Buehrer</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/thick-bridges-and-thin-bridges-in-the-same-print/#post-743927</guid>
