Thick bridges and 'thin' bridges in the same print?
Gregor Buehrer
(@gregor-buehrer)
Hi there
I need help. I am having a file that needs to have the normal bridge on one height and the thick bridge on another one.
It prints OK without the thin bridges but I get sink marks. It's a mess with thick bridges all over but no sink marks. That's why the combination would be great.
Would be good to have the two different bridge types in the same print file. However, I don't know how to do it. I don't find it as a modifier, I can only choose one bridge type for the file in the general settings. Does anyone knows how to program the thick bridges either by modifier or as a g-code in user defined g-code section?
This topic was modified 12 months ago 3 times by Gregor Buehrer
Posted : 03/04/2025 3:35 pm
LaurineSatterfield
(@laurinesatterfield)
RE: Thick bridges and 'thin' bridges in the same print?
Hi Gregor Buehrer.
Your question is a bit confusing. However, I understand that You can try using Modifier Meshes or Variable Layer Height in your slicer.
Geometry Dash
Posted : 05/04/2025 3:57 am
I don't think it's possible Gregor.  You can select thick/thin for different Objects but you cant mix them in the same Object.
Posted : 05/04/2025 8:07 am
