TBB Not Found While Compiling Prusa Slicer from Source on Mac OS
Hi, I'm trying to build PrusaSlicer from source on Mac. I am a developer but I do not have a lot of experience with C++. Definitely don't have any experience with CMake. I'm following the instructions given here. Every time I try to build dependencies. This command
cmake ..
it gives me errors. Earlier it was saying "Boost cannot be found." I fixed that by installing boost with brew. Now it's stuck on TBB.
OS X SDK Path: /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX12.3.sdk OS X Deployment Target: (default) -- Boost::boost exists CMake Error at /opt/local/share/cmake-3.22/Modules/FindPackageHandleStandardArgs.cmake:230 (message): TBB library cannot be found. Consider set TBBROOT environment variable. (missing: TBB_LIBRARIES) (found version "2020.3") Call Stack (most recent call first): /opt/local/share/cmake-3.22/Modules/FindPackageHandleStandardArgs.cmake:594 (_FPHSA_FAILURE_MESSAGE) cmake/modules/FindTBB.cmake.in:286 (find_package_handle_standard_args) cmake/modules/FindTBB.cmake:29 (include) CMakeLists.txt:384 (find_package) -- Configuring incomplete, errors occurred!
I have installed TBB. If you would notice even this error has the version listed. I have also tried installing these packages with macports instead of brew but to no avail
Posted : 17/05/2022 4:55 am
