Support Style Organic
SSFPL
(@ssfpl)
Hi all, in Print Settings -> Support material, I don't see any way of changing the support style. I see:
Support material
  • Generate support material:
  • Auto generated supports:
Options for support material and raft
  • Support on build plate only:
Am I supposed to click something somewhere to get the Style option?
I have PrusaSlicer 2.9.2
Thanks!
Best Answer by JoanTabb:
Are you in :
Beginner mode?
Normal Mode? or
Expert Mode?
Expert mode gives you access to the greatest number of features.
Have you ticked 'Generate Support Material? If not, most of the options will be greyed out.
Posted : 22/09/2025 7:47 pm
RE: Support Style Organic
Are you in :
Beginner mode?
Normal Mode? or
Expert Mode?
Posted : 22/09/2025 7:52 pm
SSFPL
(@ssfpl)
Thanks, @joantabb! We just got this machine, and I didn't realize that the print settings also change with the mode. All solved!
Posted : 22/09/2025 11:06 pm
Excellent,
Glad you are able to change the settings now...
I am currently printing some items with three standoff's under a flat bottom.
initially I used Snug Supports with PLA, and the supports were difficult to remove fully.
since then I have printed the same setup with organic supports and removal was much easier...
be careful with expert mode... you can be tempted to change a number of settings in one go, and actually make the result worse instead of better!
Posted : 22/09/2025 11:26 pm
