Support blocker/enforcer not working on multiple objects
Hello,
support blocker/enforcer not working on multiple objects even if you use separated blocker/enforcer for each object. Only single object is affected
Is there some trick? or is it a bug?
Thanks
Palo
Best Answer by 3Delight:
Each enforcement object is linked to 1 of your parts. hence why they are indented under that part name. You will need to create a second one for the other part.
Posted : 11/08/2020 8:14 pm
RE: Support blocker/enforcer not working on multiple objects
Posted : 11/08/2020 8:24 pm
