Still have first layer gap fill issues
Paul
 Paul
(@paul-2)
When I slice a model with a concentric pattern for the first layer pattern, there is always a center gap that requires filling but remains unfilled.
Is there any work around for this or plans to fix it?
When I slice the same model in Cura with concentric pattern for the first layer the gap gets filled.
Thanks!
gap issue center gap doesn't get filled
Opublikowany : 25/03/2021 5:00 pm
Paul
 Paul
(@paul-2)
RE: Still have first layer gap fill issues
BTW, with most other "First Layer Patterns" all gaps get filled, it's the concentric pattern that's flawed.
Please fix this, thank you!!
Opublikowany : 17/04/2021 5:08 pm
This is a user to user forum. We don’t have any power to fix anything. All bug reports and feature requests need to be made over on the Prusa slicer GitHub. However this has been reported several times so opening a new issue is pointless.
Opublikowany : 17/04/2021 10:34 pm
Paul
 Paul
(@paul-2)
Thanks for the clarification.
I did come up with a simple workaround if anyone is having a similar issue.
I just added a modifier for the first layer and increased the number of perimeters until the gap was filled.
Opublikowany : 26/04/2021 10:59 pm
