Spool run out detection --> automatic change, material use from second head
Tomas Drbohlav
(@tomas-drbohlav)
Is there any way in Prusa Slicer or through GCode editing to solve the following?
I use Prusa XL Multitool printer. I am printing large volume objects. Is there any oportunity to automatically use filament (identical material) from second spool when first spool runs out?
Best Answer by FoxRun3D:
Check out
It's not in Prusaslicer but I think it makes more sense to have it on the hardware side as the location of the spools you want to join may change.
Opublikowany : 11/05/2024 7:53 am
Check out
This post was modified 2 years temu by
Opublikowany : 12/05/2024 11:00 am
Tomas Drbohlav
(@tomas-drbohlav)
RE: Spool run out detection --> automatic change, material use from second head
Thank you so much for sharing this knowledge. I didn't expect the solution to be right in front of my eyes 🙂
Opublikowany : 12/05/2024 11:41 am
