					                		Speed adjustments - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/speed-adjustments/</link>
                <lastBuildDate>Sun, 15 Mar 2026 08:43:25 +0000</lastBuildDate>
                        <title>RE: Speed adjustments</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/speed-adjustments/#post-757594</link>
                        <pubDate>Tue, 15 Jul 2025 15:50:39 +0000</pubDate>
                        <description><![CDATA[Thank you both for the replies. I&#039;ve since found that I can make the change in the gcode with the M220 SXX command. I&#039;ll probably start there, and then incorporate the MVS tweaks as needed f...]]></description>
                        <content:encoded><![CDATA[Thank you both for the replies. I've since found that I can make the change in the gcode with the M220 SXX command. I'll probably start there, and then incorporate the MVS tweaks as needed further down the road.]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>jgorniak</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/speed-adjustments/#post-757594</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/speed-adjustments/#post-757524</link>
                        <pubDate>Mon, 14 Jul 2025 23:03:13 +0000</pubDate>
                        <description><![CDATA[For slowing down, yes you can lower the MVS (if changing MVS in the printer profile doesn&#039;t do anything, make sure that the filament profile override isn&#039;t set to something). I would caution...]]></description>
                        <content:encoded><![CDATA[<p>For slowing down, yes you can lower the MVS (if changing MVS in the printer profile doesn't do anything, make sure that the filament profile override isn't set to something). I would caution about raising the MVS unless you are tuning MVS for a specific filament. Go too high and you risk running into extruder skipping once you start exceeding what physics will allow for your filament type, nozzle size/type, and nozzle temperature.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/speed-adjustments/#post-757524</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/speed-adjustments/#post-757217</link>
                        <pubDate>Sat, 12 Jul 2025 07:42:50 +0000</pubDate>
                        <description><![CDATA[Changing speed in the printer menu changes only specific moves, so sometimes it does nothing due to the complexity of the printed model.The most important settings in PrusaSlicer are:- max v...]]></description>
                        <content:encoded><![CDATA[<p>Changing speed in the printer menu changes only specific moves, so sometimes it does nothing due to the complexity of the printed model.</p><p>The most important settings in PrusaSlicer are:</p><p>- max volumetric speed https://help.prusa3d.com/article/max-volumetric-speed_127176</p><p>- layer height (as far as I remember 60% of the nozzle diameter) </p><p>Bumping MVS usually needs changes per filament type and usually may need bumping nozzle temperature. Layer height gives the biggest visible speed up for the price of the worse look ( layers are more visible), so it may be good idea only for certain prints.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>_KaszpiR_</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/speed-adjustments/#post-757217</guid>
                        <title>Speed adjustments</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/speed-adjustments/#post-757029</link>
                        <pubDate>Thu, 10 Jul 2025 16:46:35 +0000</pubDate>
                        <description><![CDATA[I&#039;m guessing that this has probably been addressed a number of times, but I can&#039;t seem to find a definitive answer (if there is one).
I know that I can change the print speed at the print...]]></description>
                        <content:encoded><![CDATA[I'm guessing that this has probably been addressed a number of times, but I can't seem to find a definitive answer (if there is one).
I know that I can change the print speed at the printer under the tune setting. Let's say that I want to print at 75% speed. One setting, change the speed, and done. What would be the equivalent change to make in Prusa Slicer to accomplish the same thing? I'm guessing that there are a few parameters that would have to be addressed to accomplish the same thing.
I guess, in other words: what exactly is changed when I adjust the speed setting at the printer, and what are the corresponding changes that I can make in Prusa Slicer beforehand?]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/speed-adjustments/#post-757029</guid>
