					                		Sovol SV06Ace profile start g-code - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/</link>
                <lastBuildDate>Sat, 07 Mar 2026 23:38:38 +0000</lastBuildDate>
                        <title>RE: Sovol SV06Ace profile start g-code</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-780311</link>
                        <pubDate>Sat, 31 Jan 2026 15:22:47 +0000</pubDate>
                        <description><![CDATA[Updated G-codeG28 ;home all axis
G1 Z5 F5000 ;lift nozzle
M140 S;set bed temp
M190 S;wait for bed temp
START_PRINT
G90
G1 X0 F...]]></description>
                        <content:encoded><![CDATA[<p>Updated G-code</p><pre contenteditable="false">G28 ;home all axis
M140 S;set bed temp
START_PRINT
G90
G1 X0 F6000
G1 Y20
G1 Z0.400 F600
G1 Y-4 F6000M400
M104 S0 ;Stops PS/SS from sending temp waits separately
G90
G1 X0 F6000
G1 Y20
G1 Z0.400 F600
G1 Y-4 F6000
M400
M104 S235 ;set extruder temp
M109 S235;wait for extruder temp
G91
M83
G1 E-0.200 Z5 F600
G1 X{print_bed_max / 3} F6000
G1 Z-4.800 F600
G1 X{print_bed_max / 6} E{print_bed_max / 6 * 0.24} F3000
G1 X{print_bed_max / 6} E{print_bed_max / 6 * 0.16} F3000
G1 Y1 E0.16 F3000
G1 X-{print_bed_max / 6} E{print_bed_max / 6 * 0.16} F3000
G1 X-{print_bed_max / 6} E{print_bed_max / 6 * 0.24} F3000
G1 Y1 E0.24 F3000
G1 E-0.200 Z1 F600
M400
Select Emit temperature commands automatically
End G-code
END_PRINT
M73 P100 R0</pre>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>shep</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-780311</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-763640</link>
                        <pubDate>Sun, 07 Sep 2025 13:12:25 +0000</pubDate>
                        <description><![CDATA[Using OpenBSD/firefox-esr and the file shows up in the Attach file dialog in the lower left.  Then clicking upload and get a Prusa Orange time spinner in the upper right.  Takes 20-30 second...]]></description>
                        <content:encoded><![CDATA[<p>Using OpenBSD/firefox-esr and the file shows up in the Attach file dialog in the lower left.  Then clicking upload and get a Prusa Orange time spinner in the upper right.  Takes 20-30 seconds and then I get a notification that the post is awaiting moderation.  After several hours, the post is viewable but no attachment.  Here's the g-code:</p><pre contenteditable="false">G28 ;home all axis
START_PRINT
G90
G1 X0 F6000
G1 Y20
G1 Z0.400 F600
G1 Y-4 F6000
M400
M140 S60 ;set bed temp
M190 S60 ; wait for bed temp
G90
G1 X0 F6000
G1 Y20
G1 Z0.400 F600
G1 Y-4 F6000
M400
G91
M83
G1 E-0.200 Z5 F600
G1 X73.3333 F6000
G1 Z-4.800 F600
G1 X36.6667 E8.8 F3000
G1 X36.6667 E5.86667 F3000
G1 Y1 E0.16 F3000
G1 X-36.6667 E5.86667 F3000
G1 X-36.6667 E8.8 F3000
G1 Y1 E0.24 F3000
G1 E-0.200 Z1 F600
M400
G90G21
M83 ; use relative distances for extrusion
----****----End G-code----****----
END_PRINT
M73 P100 R0</pre><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-763640</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-763594</link>
                        <pubDate>Sat, 06 Sep 2025 22:33:49 +0000</pubDate>
                        <description><![CDATA[Second try:  SV06Ace.zip file with limited *.ini (0.4nozzle and 2 PETG filaments) and working/tested g-code.]]></description>
                        <content:encoded><![CDATA[<p>Second try:  SV06Ace.zip file with limited *.ini (0.4nozzle and 2 PETG filaments) and working/tested g-code.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-763594</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-763591</link>
                        <pubDate>Sat, 06 Sep 2025 21:33:00 +0000</pubDate>
                        <description><![CDATA[No attachment, you probably need to zip compress the ,ini file, and attach the zip fileregards Joan]]></description>
                        <content:encoded><![CDATA[<p>No attachment, <br /><br />you probably need to zip compress the ,ini file, and attach the zip file<br /><br />regards Joan<br /><br /><br /></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-763591</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-763561</link>
                        <pubDate>Sat, 06 Sep 2025 16:56:30 +0000</pubDate>
                        <description><![CDATA[I finally have a working SV06Ace profile that I&#039;ve used to print a prototype scalpel handle with PETG.  The nozzle temperatures in the start code are for California Filament PETG.  Or you ca...]]></description>
                        <content:encoded><![CDATA[<p>I finally have a working SV06Ace profile that I've used to print a prototype scalpel handle with PETG.  The nozzle temperatures in the start code are for California Filament PETG.  Or you can use in attached *.ini but the settings are not mainstream.  You may want to revert to the defaults after importing.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-763561</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-735763</link>
                        <pubDate>Sun, 09 Feb 2025 02:52:33 +0000</pubDate>
                        <description><![CDATA[Hey were you ever able to get this working? I&#039;ve been trying do the same because orca does not work well on linux. I&#039;m also new to 3d printing so I don&#039;t want to get something wrong]]></description>
                        <content:encoded><![CDATA[<p>Hey were you ever able to get this working? I've been trying do the same because orca does not work well on linux. I'm also new to 3d printing so I don't want to get something wrong</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>Ged</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-735763</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-732388</link>
                        <pubDate>Sat, 11 Jan 2025 16:35:31 +0000</pubDate>
                        <description><![CDATA[@neophyl Thanks.Given the forking of the different slicers back to SuperSlicer, I&#039;m kinda surprised that the allocation of the configuration variable varies between the projects.  I&#039;ve heard...]]></description>
                        <content:encoded><![CDATA[<p>@neophyl Thanks.</p><p>Given the forking of the different slicers back to SuperSlicer, I'm kinda surprised that the allocation of the configuration variable varies between the projects.  I've heard that Prusa has such consistent manufacturing that resonance compensation is built in.</p><p>The main reason I went with the SV06 Ace over an MK4S kit was the adoption of Kipper and I will likely mod it in the future.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-732388</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-732370</link>
                        <pubDate>Sat, 11 Jan 2025 13:57:30 +0000</pubDate>
                        <description><![CDATA[My SV08 is relatively new, one of those black friday purchases :)  I started with the default orca profiles, decided (again) that I really don&#039;t like Orca&#039;s gui layout compared to PS.  I got...]]></description>
                        <content:encoded><![CDATA[<p>My SV08 is relatively new, one of those black friday purchases :)  I started with the default orca profiles, decided (again) that I really don't like Orca's gui layout compared to PS.  I got it working fairly well though and then did a PS profile to match. </p><p>I will attach a project file that has the printer profile as well as a basic print and filament profiles too but I'm not sure how much it will help.  Due to the fact that most of the config with Klipper is done in its files, especially Printer.cfg and Macro.cfg.</p><p>When you load it, it should warn you about a missing post process script.  This is for Small Area Flow Control.  That's something built into Orca now and I was using it with that.  I was also using the stand alone processor in PS for my Klipperised Elegoo Max 3 previously.  Makes your top layers much better when set up well.  </p><p> </p>
<div id="wpfa-173296" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/wpforo/default_attachments/1736603850-90c482ea-sv08-project.zip" target="_blank" title="90c482ea-sv08-project.zip"><i class="fas fa-paperclip"></i>&nbsp;90c482ea-sv08-project.zip</a></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-732370</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-732323</link>
                        <pubDate>Sat, 11 Jan 2025 00:54:44 +0000</pubDate>
                        <description><![CDATA[I did manage to compile the most recent Orca Slicer git pull (tag  e315586) on Debian and Arch but I still think it would be valuable to have a PrusaSlicer profile. @neophyl, are you happy w...]]></description>
                        <content:encoded><![CDATA[<p>I did manage to compile the most recent Orca Slicer git pull (tag  e315586) on Debian and Arch but I still think it would be valuable to have a PrusaSlicer profile. @neophyl, are you happy with your SV08 profile in PS?  Is it similar to a Voron 2.4 profile?  Can you post it somewhere?  Just interested in having something to start with on the SV06 Ace.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-732323</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-732318</link>
                        <pubDate>Fri, 10 Jan 2025 23:15:55 +0000</pubDate>
                        <description><![CDATA[As pointed out initially the placeholders you have arent the correct ones for Prusa Slicer.  If you do not use the correct ones then the temperatures wont be pulled through.For the Sovol SV0...]]></description>
                        <content:encoded><![CDATA[<p>As pointed out initially the placeholders you have arent the correct ones for Prusa Slicer.  If you do not use the correct ones then the temperatures wont be pulled through.</p><p>For the Sovol SV08 which is klipper based you just install an actual Voron profile and then adjust the bed size and height to match.  Then adjust from there.</p><p>The whole thing with Klipper is that you dont do most of the start and end stuff in the slicer (still have to pass on the placeholders to whatever Klipper variables you have in the Klipper configs).  But most of the actual stuff that you want to control like cleaning, meshing et is all handled by editing your Klipper Print.cfg and Macro.cgf files.  and for those you need the Klipper documentation and the lots of examples of customising that are available.</p><p>I've recently gone through all that for my SV08.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/sovol-sv06ace-profile-start-g-code/#post-732318</guid>
