Slicer Issue
Patea
(@patea)
Miembro
Slicer Issue
Hi , I have an issue with the slicer. I have imported an object from fusion 360. Once imported, multiple objects are present but once sliced some of them are missing and i don't know why. I've already printed this name tag in the same way earlier, but all of a sudden, it is not working anymore while I haven't changed any parameters. Does anyone have an idea plz ?
Respondido : 25/05/2025 6:20 pm
Sembazuru
(@sembazuru)
RE: Slicer Issue
Order matters for which part will clip the other, lower parts in the list will clip higher parts. You can drag and drop the parts in the list to get an order that you want.
See my (limited) designs on:
Respondido : 26/05/2025 2:38 am
RE: Slicer Issue
could be a lot of things. If you can save the project as a 3mf file, zip compress it (don't skip this step) and attach it to a post using Attach file, we can see the model and settings and make educated suggestions.
Respondido : 26/05/2025 1:29 pm
Patea
(@patea)
Miembro
RE: Slicer Issue
Thank you very much Sembazuru. You're solution worked very well. I changed the object order and everything is good now. Thank for your answer.
Respondido : 28/05/2025 4:18 pm
2 les gusta
