Slicer G Code
Retired
(@retired)
Slicer G Code
What is the Slicer G code for PAUSE? I want to stop the print at a specified Z height to insert something.
Posted : 23/01/2020 11:01 pm
Area51
(@area51)
RE: Slicer G Code
M601 - Pause print
G-codes for Prusa Marlin can be found here: https://prusa3d.github.io/Prusa-Firmware-Doc/group__GCodes.html
Posted : 24/01/2020 12:50 am
Retired
(@retired)
RE: Slicer G Code
Thanks for your help.
Harley
Posted : 24/01/2020 5:35 pm
Sembazuru
(@sembazuru)
RE: Slicer G Code
The code that I use is a little more complex than the simple M601. I haven't used an M601 yet so I don't know how the Prusa firmware responds to that command. (For all I know, it is just as good as my code snippet... I haven't taken the time to experiment yet.)
Here is the code snippet that I put into the custom "Before layer change G-code":
{if layer_z==4.20}; Change this to the intended height of the pause
M400 ; wait for movement buffer to empty
M300 ; beep
M104 S0; Turn off extruder heater to avoid too much oozing
; code snippet originally Prusa forums joantabb here: https://forum.prusa3d.com/forum/original-prusa-i3-mk2-s-others-archive/pause-print-in-gcode/#post-125758
G1 X10.000 Y200.000 E0; parking position GET THE PRUSA TO STICK IT'S TONGUE OUT! (edited to revise Y coordinate)
M400; wait for bed to stop moving
M300; beep again
M84; disable motors (may not be necessary)
M0; user stop, execution will continue with the next line once the user presses the select button on the printer
M104 S[temperature]; Start re-heating the extruder but don't pause code execution.
G28 X Y; Home X and Y (only) to correct for accidentally moved bed or extruder (it is assumed Z didn't move because that is a harder axis to manually move).
M109; wait for the nozzle to return to printing temperature
{endif}
I disable the motors in my code so if I don't get to the printer right away then the motors aren't using energy to hold position both saving a little electricity and allowing the motors to cool down.
I haven't played with the 2.2.0 alpha releases yet to see if my multi-line block of g-code will work in the new "insert g-code at specified layer" feature. I probably should try so if it doesn't I have a chance to submit a bug report/feature request before 2.2.0 becomes finalized...
See my (limited) designs on:
Posted : 24/01/2020 6:15 pm
Retired
(@retired)
RE: Slicer G Code
Thanks for your help I forgot about the beep which would be good. If you shut off the motors you would be able to move the extruder and bed around?
Harley
Posted : 24/01/2020 11:31 pm
Sembazuru
(@sembazuru)
RE: Slicer G Code
Posted by: @kelsey-harley
Harley
Yes the extruder and bed are moveable. That is why I home the x and y after the print resumes. I don't home on the z axis because I'm fairly confident that moving the z is difficult enough to do by hand and I didn't want to risk hitting a tall print with the x axis gantry. My experience using this is the y does get moved easily when inserting objects, especially if there is a tight fit.
Posted : 25/01/2020 1:28 am
