Slicer adds solid infill
Trying to figure out why Prusa Slicer is adding these purple solid infills on the inside walls of this planter print. Original STL was created for vase mode but I opted for 3 perimeters, 0 solid layers on top and 5 solid layers on the bottom. Trying to figure out which checkbox to check/uncheck to get rid of these unnecessary additions to the inner wall. Thanks!
Respondido : 21/09/2024 9:33 pm
I assume you have just set the fill to 0% ?
If so the slicer will proceed to produce an outer perimeter but nothing inside. You need to hollow your model in CAD so that the walls have two sides for which the slicer will generate perimeters.
Vase mode is an oddity which prints only the outside of a solid shape - because you want thickness you have to provide a hollow shape.
Respondido : 22/09/2024 5:52 am
RE: Slicer adds solid infill
Respondido : 22/09/2024 9:23 am
