Slicer adding logo into middle layers
Sitar Dankur
(@sitar-dankur)
I cannot quite understand what is happening with the slicer. For some reason indents or extrusions from text are being duplicated layers behind or after only in one layer but for no reason. I built the model and the entire thing is solid minus a .15 indent below and then a .3 extrusion above. But it's created two layers in the middle that are somewhat copies of that indent/extend layer. Am I missing a setting that's checked or something? The 2nd through 5th layers are 90% infill. So essentially 100%. But if I change to 100% rectilinear infil, it makes that even worse of a layer difference. Changing off of rectilinear and down to 90% fixes it some. Any thoughts?
Layer 6:
Layer 6
Layer 1:
Layer 1
If i change back to 100% infill and rectilinear it inputs the same thing from above as a duplicate in layer 15 when it starts in layer 21:
Napsal : 08/05/2025 11:32 pm
Sitar Dankur
(@sitar-dankur)
RE: Slicer adding logo into middle layers
Took a while to find but I realized that has to do with outter layer infills for horizontal layers. Requiring 5 solid infills before the "inner" of an object can begin, due to only having 1 layer of an indent with text, once I get to layer 6 then the final "solid infill" is complete but because that small section is the final layer required, than actual infill it is a still considered an "outter layer" for the slicer and so it separates that from the normal infill settings. Rinse repeat for the top one.
Napsal : 09/05/2025 12:34 am
SergePix
(@sergepix)
I have the same problem. On the fifth layer from the bottom, the text repeats.
I can't remove this text; it serves no purpose and takes longer to print.
Napsal : 24/05/2025 8:45 pm
SergePix
(@sergepix)
Napsal : 24/05/2025 8:47 pm
