Slicer 2.3 and Ironing
I cannot prove this in a court of law like, but I have been using the slicer beta for a while now and of the three times I elected to use the ironing feature two things happened:
1. The extruder motor got real hot.
2. The nozzle eventually blocks right up.
Has anyone else experienced this?
RE: Slicer 2.3 and Ironing
I don't own a Prusa so I can't say anything definitive but when I played with ironing in Cura I found that getting the flow correct was critical (I settled on 5% I think).
I've tried ironing with both Cura and PS, and IMAO, the function in PS worked better out of the box. I plan to experiment more.
I have a heat sink on my extruder motor and using an infrared thermometer gun, the heat sink typically runs in the high 30s to low 40s during a longer print. I'll sure (try to remember to) take some measurements when it's doing the top layer when I play with ironing again.
I tried the ironing after reading this post, my extruder didn't get much hotter then normal, it was around 50C I measure from the back of the extruder motor (the part that faces you) and thats about average based on other times I've measured.
I was using Clear PETG, I did experience periods of mild extruder clogging, I didn't play with it though, I ran it with default settings, I wasn't impressed by it and don't have much use for it, aside from the one feature that didn't work at all, the " All solid surfaces" so I didn't fiddle with it more after that. the clogging I experienced was intermittent and mild, I was able to get better and constant results by turning up the heat a bit on the PETG.
The Filament Whisperer
I meant to say, I was able to get better and constant results by turning up the heat a bit on the PETG and not using ironing. but as we all know you can't edit your posts here. 😡
I haven't noticed any nozzle blocking from ironing.... at least not yet. I was using an E3D 0.6mm brass nozzle and PETG filament.
@garethsnaim What kind of nozzle and what diameter were you using? What kind of filament?
I'm guessing one of the plated nozzles would work best for this kind of thing.
A heat sink on a stepper sounds like a great idea. Would you mind posting a photo? In would provide context for your measurements.
Here you go ...
I have quite a few of these in the parts junkbox so I grabbed one and stuck it to the laminations on the stepper using thermally-conductive adhesive. I thought of pasting one or two more on, but after measuring the heat, it did not seem necessary.
Now, yesterday I had to print a lamp holder for a model I'm building and just for the heck of it and to test I turned on ironing. No obvious heat difference (more or less consistent 38C) as it 'ironed' the lowest flat surface. Granted, it was not a large surface, but it sure did not zoom up the heat on the extruder motor.
@dimprov
Standard Brass 0.4 nozzle with Overture transparent PETG at 252C, stock generic PETG profile with the heat turned up a tad.
It turns out the amount of allowed extruder stepper current varies depending on whether you have chosen a DETAIL or SPEED setting. Which were you using? Consider the default Start g-code:
; Don't change E values below. Excessive value can damage the printer.
{if print_settings_id=~/.*(DETAIL @MK3|QUALITY @MK3).*/}M907 E430 ; set extruder motor current{endif}
{if print_settings_id=~/.*(SPEED @MK3|DRAFT @MK3).*/}M907 E538 ; set extruder motor current{endif}
Hi, sorry, you may as well have written that in Klingon.
I cannot remember which setting I used but typically I use .20 quality.
